Old 22-08-2005, 04:44 PM   #1 (permalink)
Default ((((((((((((((|Computer||or||Pandora's||Box?||)))) ))))))))))
I have a computer quite old though wih the configuration
-Intel Pentium 3 596MHz
-128 mb ram
-40 gb hdd
and the folloing problems
1-slow booting when the LAN in plugged 50%slow
2-in task manager,in processes,i cannot see the user name
3-Mic does not work
4-new software/games donot install
5-I CANNOT BOOT IN SAFE MODE!
(GETS RESTARTED AUTOMATICaLLY!)
any solution?
is there no option for me except for buying a new on?
plss help me!
rahulstein is offline
Old 22-08-2005, 04:55 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
For your second problem in TaskManager go to View>>Select Columns and check against user name.
For your fifth problem press F8 when PC restarts and you will get a boot menu showing option for Safe Mode. If you do not want it to restart automatically go to MyComputer>>right click>>Advanced tab>>Startup and recovery>>settings and now uncheck against automatically restart and click OK.
navjotjsingh is offline
Old 22-08-2005, 05:00 PM   #3 (permalink)
godsownman's Avatar
I feel u should invest in a new one.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 22-08-2005, 05:01 PM   #4 (permalink)
godsownman's Avatar
Old 22-08-2005, 05:08 PM   #5 (permalink)
Same here..go for a new one...even i have a similar config. PIII 733 Mhz 20 gb hdd and even i m thinking of going a amd 64bit s939 system
cyrux is offline
Old 22-08-2005, 05:25 PM   #6 (permalink)
expertno.1's Avatar
are yaar get a new one
which os u r using ?
expertno.1 is offline
Old 22-08-2005, 05:39 PM   #7 (permalink)
siriusb's Avatar
Since the problem isn't hardware related, i feel he don't have to upgrade (except for no:4).
1. http://answers.google.com/answers/threadview?id=555853
http://www.annoyances.org/exec/forum/winxp/t1041630673
3. Check the volume control, correct jack, etc. Check ur mic in some other's system to see if that is the culprit.
4. Maybe it's time to buy a new grafx card and cpu and more ram, or try http://www.3dfxzone.it/dir/tools/3d_analyze/
5. Try disabling "Automatically restart after error" in system properties. It's probably a blue screen.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-08-2005, 08:56 AM   #8 (permalink)
Thank u!
I'll buy a new computer.
And fix all these problems just because of your help!
Old 23-08-2005, 09:00 AM   #9 (permalink)
MVP in VC++
since u r having old config u may face various problems in either software or in hardware so better invest for a new one dude.........
cvvikram is offline
- by Krow
