Old 22-08-2005, 04:23 PM   #1 (permalink)
expertno.1's Avatar
Default Hard Disk Sound Leads To Hanging Help !!!!!
from two three days i am finding that sometime my harddisk creates a sound like this "tarak" "tarak" seems like any metal is beating the hard disk
and the hell is that whenevr the sound comes my comp hangs for 5-6 seconds
the length of the sound is "2-3" seconds
whenver the sound comes my computer hangs but comes again after 10-20 seconds
Help me Yaar
sometimes even the sound goes on tarak tarak tarak tarak tarak and contimues and my comp gets hanged for 40-50 seonds
plz help
expertno.1 is offline
Old 22-08-2005, 05:29 PM   #2 (permalink)
Is this sound like "clicking".
My suggestion would be to first backup all your data & then make sure its indeed from the hard drive.When it comes to failing hard drives there are no second chances to backup your data.
Try enabling S.M.A.R.T from the BIOS & see if it gives any indication of a failing drive.
www.Oobertech.net
digen is offline
Old 22-08-2005, 08:05 PM   #3 (permalink)
expertno.1's Avatar
well is there any risk
yes the sound is clicking sound
also
enabling S.M.A.R.T will tell me when the hard disk is going to crash ? how will it tell me i mean in which interface
Old 22-08-2005, 08:39 PM   #4 (permalink)
Dude if you are sure its the "clicking" sound then backup your data first.Copy or clone the drive using disk imaging software & then try what its undergoing.
Yes,enabling S.M.A.R.T will in most cases inform you of the state of the hard drive[i.e it predicts the drive of any failures occur in the near future & thereby ask you to backup your data or replace to a new hard drive]
Try out [url=http://www.ariolic.com/activesmart/]Active S.M.A.R.T/url] for a windows GUI alternative to S.M.A.R.T from BIOS.
Enable S.M.A.R.T on the drive which is failing on you.Try with active smart first if no such option exists in the BIOS.
www.Oobertech.net
digen is offline
Old 22-08-2005, 09:09 PM   #5 (permalink)
q3_abhi's Avatar
You will get a message at the boot up. Something SMART failure detected. I get this problem everytime as my disk has developed some bad sectors but it's working fine.
Back up ur data n format ur hard disk with DM - Disk manager.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 23-08-2005, 12:20 AM   #6 (permalink)
This happened to my older HDD. But I was lucky that it was in the warrenty. I got it replaced. expertno.1 I'm sorry but I think your HDD is in its last stages!!
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 23-08-2005, 06:30 AM   #7 (permalink)
expertno.1's Avatar
hey hey but many times the clicking sound doesn't comes like this time i am posting there is no sound from the beginnign of the booting process
also
i have enabled S.M.A.R.T
will backup my data
- by Krow
