Old 22-08-2005, 01:14 PM   #1 (permalink)
Default Problem with my new rig
Hi Guys,
Thanks for all ur guides and suggestions, I just got the following rig :
AMD Athlon 64 3000+ venice core
ASUS A8N-E Mboard
512 MB DDR 400 Transcend RAM
Leadtek 6600GT
I assembled the system and am encountering the following problem :
1 . I have enabled cool & Quiet in the BIOS and installed all drivers provided in the CD. I then installed the COOL & QUIET s/w but it does not work giving me an error - "can`t open IO.SYS " and "EAccessviolation". What could be the problem ? And how do I rectify this ? By the way I have not installed Ai Booster as specified on the manual.
Aparajith .S
AMD Athlon 64 3000+ [ Venice core ] , Asus A8N - E Motherboard, 1 GB DDR 400 Transcend RAM, Leadtek 6600 GT Graphics card, Hitachi 160GB 7200rpm SATA 2 running Windows XP Professional Edition with SP2
Aparajith is offline
Old 22-08-2005, 02:57 PM   #2 (permalink)
which os are u using ?
are u tryin to use winxp 64 bit ?
i think cool n quiet has issues with that .
besides there are separate 32 bit and 64 bit versions of it i think
No Mercy, No Limits.
theraven is offline
Old 22-08-2005, 03:49 PM   #3 (permalink)
expertno.1's Avatar
can u tell me the OS u r using ?
expertno.1 is offline
Old 22-08-2005, 03:56 PM   #4 (permalink)
siriusb's Avatar
It's an application error (possibly) from asus cool n' quiet app. Reinstall the cool 'n quiet drivers and then install the asus cool 'n quiet.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 22-08-2005, 10:16 PM   #5 (permalink)
Am using Windows XP with SP2 - a 32bit OS. Also I have tried uninstalluing, reinstalling as much as possible. Even cleaned the registry but to no avail. Am trying to contact ASUS by the way. Let me see if they can reply me.
Aparajith .S
Old 23-08-2005, 03:28 AM   #6 (permalink)
mate no need to install the cool and quite software or drivers fo amd 64 in windows xp
you should just visit amd.com and install the latest processor drivers
after that go to the power options(from the screen saver dialog of display properties) and then select the "minimal power managment" power scheme. and thats it your cool and quite is up and working
for verification you can use cpuz
also you can then set the different time outs( for switching of the display) in the power option as per your choice but make sure the scheme does not changes
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
- by Krow
