Old 22-09-2004, 05:09 PM   #1 (permalink)
Default BIOS aperture size????
can anyone tell me that how to.........
"Set the AGP aperture size to 256MB in the Bios??".
kajal is offline
Old 22-09-2004, 05:28 PM   #2 (permalink)
Which BIOS and Motherboard you have ?
Think of me n I will be there
amistik is offline
Old 22-09-2004, 05:48 PM   #3 (permalink)
i had an intel 845G i think. i cant find it now, but earlier i found an option somewhere in the bios to change the video agp aperture size.i hav no idea now ware d option is.
i had gotten 640mb ram from 128mb, so i set the aperture size to 256. but now in windows, the video memory has increased from 32 to 48 only. (i checked thru dxdiag and display properties.) is it some kinda limit on onboard gfx or something else ?
ishaan is offline
Old 22-09-2004, 05:55 PM   #4 (permalink)
Check this link. It might be helpful
http://www.ocfaq.com/article.php/ove...ing/vidcard/43
amistik is offline
Old 22-09-2004, 06:07 PM   #5 (permalink)
thx...i thot it wz da same thing as vid memory but now i kno wat it is.
ishaan is offline
Old 22-09-2004, 06:39 PM   #6 (permalink)
One more piece of info to tip amistik's link
http://www.rojakpot.com/default.aspx?location=9
Also check the BIOS Optimization guide at the url given above.
www.Oobertech.net
digen is offline
Old 23-09-2004, 01:23 PM   #7 (permalink)
Thats a great link. thanks digen
amistik is offline
Old 23-09-2004, 01:40 PM   #8 (permalink)
gxsaurav
Posts: n/a
set it to 64 MB that enough for your system
- by Krow
