Old 21-08-2005, 08:37 PM   #1 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default A java Problem
A java problem...
heres the code
import java.io.*;
class DNA
	public static void main(String args[]) throws IOException
		String A;
		char a;
		int i,j;
		DataInputStream in = new DataInputStream(System.in);
		A=in.readLine();
		j=A.length();
		StringBuffer Str = new StringBuffer(1000);
		StringBuffer Str1 = new StringBuffer(1000);
		for(i=0;i<=j;i++)
		   a=A.charAt(i);
 		   switch (a)
			case 'A' :
				Str1=Str.insert(i,'T');
			case 'T' :
				Str1=Str.insert(i,'A');
			case 'C' :
				Str1=Str.insert(i,'G');
			case 'G' :
				Str1=Str.insert(i,'C');
			case 'B' :
				Str1=Str.insert(i,'V');
			case 'V' :
				Str1=Str.insert(i,'B');
			case 'D' :
				Str1=Str.insert(i,'H');
			case 'H' :
				Str1=Str.insert(i,'D');
			case 'K' :
				Str1=Str.insert(i,'M');
			case 'M' :
				Str1=Str.insert(i,'K');
			case 'Y' :
				Str1=Str.insert(i,'R');
			case 'R' :
				Str1=Str.insert(i,'Y');
			case 'S' :
			case 'W' :
			case 'N' :
			default :
			System.out.println("The Pair Structure That You Have Entered is Invalid, Please Restart the Program and Enter Again.");
		System.out.println("The DNA Pair You Entered is "+ A);
		System.out.println();
		System.out.println("The Decoded DNA Pair is "+ Str1);
It gives an error and closes on Enterin the data and pressing ENTER sayin that
Exception in thread "main" java.lang.StringIndexOutOfBoundsException: String index out of range: 2
	at java.lang.String.charAt(Unknown Source)
	at DNA.main(DNA.java:27)
Line 27 is
		   a=A.charAt(i);
What is the problem here ?
The Syntaxes r all correct...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2005, 08:43 PM   #2 (permalink)
siriusb's Avatar
The for loop shud be
for(i=0;i<j;i++)
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 21-08-2005, 11:39 PM   #3 (permalink)
#/bin/sh's Avatar
This
for(i=0;i<=j;i++)
should be
for(i=0;i<j;i++)
As the string position starts from 0 whereas the length of the string gives you the total length.
When j=0, the String A is empty or null and hence there is nothing at position 0. Similarly, when j=2, the characters are at the positions 0 and 1. So, your iteration for i=2 (i<=j when j=2) will be:
a=A.charAt(2);
It fails because there is nothing at position 2.
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 22-08-2005, 01:21 AM   #4 (permalink)
#/bin/sh's Avatar
You should have break statement in a case statement or it will fall through and evaluate all below once you've 'scored a hit'
#/bin/sh is offline
Old 23-08-2005, 06:36 PM   #5 (permalink)
Commander in Chief
Thnx , heres my new code for time being..
I want to know how to save the output characters in a string...or an array so that i can store it in a file..
Also i want to know how to make this an applet..
Plz help...
import java.io.*;
import java.applet.*;
import java.awt.*;
public class DNA
	public void start()throws IOException
		String A,Author;
		char a,ans[];
		int i,j;
            System.out.println("Enter The Strand :");
		A=in.readLine();
		A=A.toUpperCase();
		j=A.length();
		ans = new char[100];
		j--;
		for(i=0;i<=j;i++)
		  a=Str.charAt(i);
		   if (a=='A')
		   System.out.print("T");
		   if (a=='T')
		   System.out.print("A");
		   if (a=='C')
		   System.out.print("G");
		   if (a=='G')
		   System.out.print("C");
		   if (a=='B')
		   System.out.print("V");
		   if (a=='V')
		   System.out.print("B");
	           if (a=='D')
	           System.out.print("H");
		   if (a=='H')
                   System.out.print("D");
		   if (a=='K')
                   System.out.print("M");
		   if (a=='M')
                   System.out.print("K");
		   if (a=='Y')
                   System.out.print("R");
		   if (a=='R')
                   System.out.print("Y");
		   if (a=='S')
                   System.out.print("S");
		   if (a=='W')
                   System.out.print("W");
		   if (a=='N')
                   System.out.print("N");
Harsh J
www.harshj.com
Old 23-08-2005, 07:38 PM   #6 (permalink)
Commander in Chief
Also,
I tried using the applet code in html, but it says that it failed...
Also,
Does Applet accept datainputstreams ?
I heard that it uses somethin called AWtoolkit ...?
How to accept input using that ?
Harsh J
www.harshj.com
Old 25-08-2005, 06:31 PM   #7 (permalink)
Commander in Chief
So...
No answer to my last problem ?
Harsh J
www.harshj.com
- by Krow
