My friend has a Mercury PVCLE266M-L mobo based system.
[CPU VIA C3 Samual 2 processor onboard
FSB 133MHz
Chipset CLE266/8235]
The mobo's specification/manual tells it supports DDR266 i.e: "Memory
- 2 x 184-pin DIMM sockets support two2.5V DDR SDRAMs (DDR266)
- Maximum: 2GB "
One fine morning his single stick memory (DDR266, 256 MB) failed. After that he installed a DDR400 stick which worked well.
My questions are :
(1)" Is it advisable to use DDR400 or DDR333 on this board when the specification says it supports only DDR266 ?"
(2) " Is there any adverse/+ve effect if we use DDR400/DDR333 on this board? "
