21-08-2005, 11:58 AM
Help BLA Trojan Horse!!!!
Now a trojan horse is detected in my system iam posting the screen shots reported by Norton Antivirus 2005 i did a full system scan still not able to find that trojan horse...
This alert appears when i connect to internet.
OS version Winxp pro sp2 and jun 2005 autopatcher..
Screen Shot1
Screenshot2
Thanks in advance..........
21-08-2005, 12:45 PM
String Phreak
Try using spysweeper or adaware!
Since ur getting this alert on every net connect then the trojan is in memory(startup) i think.
So first check out the programns on startup with startup platinum or any other software!
Disable the one which u suspect is trojan!
BUt be careful gather info about every prog on startup.
If u find the trojan, find its location in ur hardiskandremove the trojan file!
Any way the above mentioned antispywares should solve ur problem!
22-08-2005, 08:57 PM
Distinguished Member
bla trojan is also referred to as the asian trojan. check out if u, inter alia, have these files in ur startup :ccrpbds6.dll and ccrpftv6.ocx. if yes, remove them from ur startup.
'anti-trojan shield' removes this malware.
http://www.atshield.com/
also suggest u switch over to avg (or avast) anti-virus. i think an anti-virus job is not just to detect, but also to remove the fxxxxxx infection !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
22-08-2005, 09:10 PM
@anandk
I checked but both files are not in my startup..(Checked using msconfig)...
Is there any freeware anti-trojan scanner.....
Thanks
22-08-2005, 09:20 PM
Just Do It
22-08-2005, 09:21 PM
Hi,
Give a try to Ewido, it's one of the best tool around.
http://www.ewido.net/en/
(You get 30 day trial, after which it shifts to Free version which does not have Realtime scanner)
http://swatrant.blogspot.com/
22-08-2005, 09:25 PM
Just Do It
Originally Posted by swatkat
Hi,
For me Xcleaner detectd and removed it.
23-08-2005, 06:08 AM
I have scanned with ewido security suite it detected lot of other spywares and removed them. But it did not remove the trojan horse.
Strangely now norton also doesnot complain of the internet worm.......
Has the Trojan really Gone?
23-08-2005, 06:32 AM
Hi,
you were also infected ?
23-08-2005, 03:40 PM
quite posbly it must'v been removed. since sevral companies give difrnt names to difrent infections.
ewido, pestpatrol are some of the better in this category.
Microsoft® MVP
23-08-2005, 08:43 PM
As i can see from the screenshot, Norton has blocked the worm/trojan. It has not entered your system.
23-08-2005, 08:58 PM
Good yaar norton has proved itself.......
Search this Thread |
