Old 21-08-2005, 09:59 AM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default How's this config for gaming?
Hi,
I have decided to go for a major upgrade and I have decided on the following specs. Finally I will ditch my 3 year old system. And as I am into gaming, I have also decided on the AMD based platform.
Motherboard:Asus A8N-E (Nforce4 ultra chipset)---Price ~ 6,500
Processor:Athlon 64 3000+ (939 pin)---Price ~ 7,500
Graphics card:Asus or XFX 6600GT 128MB DDR3 PCI-express (I am not getting the Leadtek/Gigabyte brand here in Kolkata.)---Price ~ 10,500
Total cost ~ 25,000
In addition to that I will use the 512 MB DDR RAM from the previous system. The other components essentially comes from the previous system.
Please suggest any changes. I want to be relatively futureproof for the future 2 years. I also do not have fascinations for high resolution gaming but I am satisfied with high performance at 1024X768 and 4X AA/8X AF.
I was also considering a MSI based board (MSI RX 480M2). Is this a good choice and is this cheaper than the above mentioned ASUS baord?
My total budget is around 25k....
Thanks and waiting for your suggestions...
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 21-08-2005, 10:12 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Its good for a year or so if i may say so...
P.s. try gettin a gb ram if u can go for it, else all is ok, but plz recheck prices in the sticky for the proccy...
dont think it is worth that much...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2005, 10:23 AM   #3 (permalink)
config is good...also which monior do u haVe???...btw i guess mobo price is mor..i jus got it 4 8.5k..also yup get 2 512mb ram.......will cost ard 6k(both box pack transcend-400mhz)
magnet is offline
Old 21-08-2005, 10:41 AM   #4 (permalink)
its excellent config for gaming also u can OC the cpu upto 2Ghz of speed
www.guessthelogo.blogspot.com
harshagarwal is offline
Old 21-08-2005, 10:42 AM   #5 (permalink)
Commander in Chief
Isnt 3000+ already 2~ ghz ?
Harsh J
www.harshj.com
Old 21-08-2005, 12:04 PM   #6 (permalink)
Manchester United
I think he is correct. The clock speed of the 939 pin processor is 1.8Ghz, whereas the same for 754 pin is 2Ghz, according to this chart:
http://www.amd.com/us-en/Processors/...^10248,00.html
What do you say? Then which processor should I go for? Needless to say, if I change over to 754 pin the motherboard should also change. Please give suggestions for supporting motherboard as well, and the price.
Thanks!
Old 21-08-2005, 12:09 PM   #7 (permalink)
stick to the current comob, its worth it!
Hmmm...do i need one?
sunmysore is offline
Old 21-08-2005, 12:15 PM   #8 (permalink)
Manchester United
Well, how about the MSI K8N Neo4? Is it available in India and what is the price?
Thanks..
Old 21-08-2005, 12:31 PM   #9 (permalink)
k8n neo 4 is available in india.
Cost was close to 9K few days ago and its not worth it to be honest.
A8n-e is good board. good overclocker. good stability.
ANd perfect price.
And ya, 1GB memory is almost nacessary with modern games. specially when u plan to game with eye candy on and have a card like 6600GT
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
Old 21-08-2005, 12:37 PM   #10 (permalink)
Manchester United
We are totally getting ripped off. Just to compare see this:
http://www.tigerdirect.com/applicati...?EdpNo=1366536
Comes to around 4000 bucks. And they are charging 9000!!! What the ***?
Old 21-08-2005, 12:54 PM   #11 (permalink)
the same board the guy told me for 9.5k in mumbai....the f option made me to go against it...since i was going 4 msi for firewire...but f option doesnt provide i guess
magnet is offline
Old 21-08-2005, 01:50 PM   #12 (permalink)
deathvirus_me's Avatar
get atleast a GB of memory .... also .. get the 6600GT Gamer's Edition from XFX ... its priced only about 2k's more .. but is a damm good overclocker .....
deathvirus_me is offline
Old 21-08-2005, 05:29 PM   #13 (permalink)
Manchester United
Thanks very much friends!
Old 22-08-2005, 08:53 PM   #14 (permalink)
Manchester United
Well, I might also consider this...What do you say?
http://www.thinkdigit.com/forum/viewtopic.php?t=27091
Please reply soon.
Thanks
Old 23-08-2005, 12:28 AM   #15 (permalink)
go ahead buddy thats a offer not to be misse but do check what the card 6600 or 6600 gt and by the way go for asus a8n sli delux u will be safe in future u wont have to buy a another card instead go for a nother 6600 which will be cheap by then but mind u asus mobd have had complants that the fan tends to conk of or produce sound so u ned to replace but its a good bord check msi bord too and if possible go for a asus sli premium if u can as it will increase the budget by atleat 3 thousand but because it has no fan and has a heat pipe it is good especailly for overclocking ur chipset and u wont have any of those fan problems also check the price for 6800 prices have crashed quiet a lot tc
EAT DRINK AND SLEEP 3D
ASH18MARCH is offline
- by Krow
