Hi Guys
I have AMD 3200+ running on MSI RS480M2IL with 512 *2 DDR 400 Hynix RAM
i want to add a tv tuner card to my machine, my budget is about 3 - 3.5
1.most important point is, it should have good quality recording, as i want to give it live feed form my handycam. realtime encoding will be always a added advantage.
2.should have remote control.
3.will the card be pci based or pci-x based (my mobo does not have a agp slot)
so which one should i buy?
can plz tell me will the card work with xp media center edition.
