Old 20-08-2005, 07:39 PM   #1 (permalink)
Default Help urgently !!! Prob installing PHPBB 2.0.15 on dhost.info
Trying to install PHPBB2 on dhost.info and im recieving this error while installing wat can i do to correct it ???
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) in /usr/local/apache2/htdocs/niral/Forum/Phpbb/phpBB2/db/mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /usr/local/apache2/htdocs/niral/Forum/Phpbb/phpBB2/db/mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /usr/local/apache2/htdocs/niral/Forum/Phpbb/phpBB2/db/mysql4.php on line 331
phpBB : Critical Error
Could not connect to the database
Plz help me !!
Im using Version 4.x for install .
then for Database server Hostname/dsn : localhost
my database and database usernme is the same .
and for Prefix for tables in database: phpbb_
Domain Name : dhost.info
and the remaining is no problem !!!
So wat am i doing wrong ???
Wats te problem im using
PHPBB 2.0.15
Plz help me !!!
Thanx in Advance !!![/quote]
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 20-08-2005, 11:22 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
well mate i think the MySQL database type u chose at the time of installetion wasnt right... Check their tutorial here....
http://www.phpbb.com/support/tutorials/
follow the installetion toturial....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-08-2005, 12:01 PM   #3 (permalink)
if i change it to 3.x it says Critical error could not connect to database
Old 21-08-2005, 04:21 PM   #4 (permalink)
Rebooting
hmm... then open the config.php...
put this code their...
<?php
// phpBB 2.x auto-generated config file
// Do not change anything in this file!
$dbms = 'mysql4';
$dbhost = '_______';
$dbname = '_______';
$dbuser = '________';
$dbpasswd = '******';
$table_prefix = 'phpbb_';
define('PHPBB_INSTALLED', true);
now the dbhost should b localhost, dbname what u have, dbuser what u have, password what u want.... change CHMOD permission to 666 as shown in that tutorial...
save... now try again...
rebooting
ChotoCheeta.com
Old 22-08-2005, 02:35 PM   #5 (permalink)
ur entering dhost.info as the domain name
ur tryin to install phpbb on root dhost.info
put in the domain name assigned to u
also is that the domain name ? or the mysql path ?
if its the mysql path enter localhost
No Mercy, No Limits.
theraven is offline
Old 22-08-2005, 02:42 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
I guess its the same mistake which happens every time, dbhost should be 'mysql' on dhost rather than 'localhost'. and make sure abt the 666 permissions.
Sourabh is offline
Old 22-08-2005, 02:43 PM   #7 (permalink)
Version 2.0
Deep's Avatar
king_niral..
search
the answer is in the Q&A forum, only 7-8 threads before yours...
check this: http://www.thinkdigit.com/forum/viewtopic.php?t=26549
btw one advice, get PHPBB 2.0.17 if you dont want your forums to get hacked..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 22-08-2005, 02:50 PM   #8 (permalink)
Rebooting
by the way in the phpBB web site there r some extra tools... like mods & others... hmm any tools which is must install ??
rebooting
ChotoCheeta.com
Old 22-08-2005, 10:24 PM   #9 (permalink)
Rebooting
no answer?? :roll: :roll:
rebooting
ChotoCheeta.com
Old 22-08-2005, 10:35 PM   #10 (permalink)
Version 2.0
Deep's Avatar
tools - depend upon your needs, so you need to install the one you need...
and dont install many mods coz it creates problems at the time of updating the software...
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 22-08-2005, 11:31 PM   #11 (permalink)
Generic Superhero's Avatar
Exactly so, in dhost.info, dbhost will be 'mysql' instead of 'localhost'. I learnt it from their forum when i installed php nuke in my dhost.info account.
Nipon
Generic Superhero is offline
- by Krow
