Well is there any way to remove all the traces of those shareware programs that you installed over a period of time and uninstalled it after the specified time limit or evaluation period,completely from your system without formatting and reinstalling ur OS and use them again by reinstalling the shareware program alone.
Things like Style XP never allow its use after a specified time even its reinstallation won't work.
Help ME! I want to use this cool piece of program "Horoscope Explorer Pro" for a couple more of executions and i am unable to get it running (I tried re-downloading the software but on installation it says your "evaluation period has expired")I did try those registry cleaners, junk file removers but nothing worked out.
