20-08-2005, 04:45 PM
Why the difference??
I am using dataone 256 kbps broadband.
On test I found the follwing result
Why there is a huge difference between download and upload speed
____________________________________________
A person who never made a mistake never tried anything new.
20-08-2005, 04:55 PM
Commander in Chief
Dunno exactly but i think it has got to do with latency or network card packet support...
Chk this for many reasons for low speeds :
http://www.dslreports.com/speed
Harsh J
www.harshj.com
20-08-2005, 05:50 PM
In Pursuit of "Happyness"
Oh thats very normal. When they say 256 kbps connection, they mean downloads @ 256 kbps. Uploads are usually 1/5th of the download. So dont worry!
20-08-2005, 05:57 PM
Commander in Chief
Nope, u cant possibly download at 256 kbps,
Tis divided by 2 > So 128 applicable...
Divide 128/2 for in / out > 64 in 64 out (max)
Seein the quality of cards and servers and wires , divide each by 2 and u will reach the real bandwidth...
Harsh J
www.harshj.com
20-08-2005, 06:47 PM
Another Brick in the Wall
Dont you ppl know?
We dont get more than 7-8kBps for upload in BSNL dataone. I have noticed that thing from the day, I got my connection. Because of this , I am not able to have a good ratio in some torrent sites.
No, many ISP's dont limit the upload BW. They give nearly 30kBps upload on a 256k line.
20-08-2005, 07:12 PM
are yaar i dont think the upload will also be 256
it will be less
and about bsnl's speed yes it gives uploads of 7 kbps-8kbps ?
are yaar jab modem ka maximum speed 5.6 KB/s hai tab how is it 7-8 KB/s ?????????????????????
20-08-2005, 07:24 PM
wat r u talkin about ????
well i have a 256 KBps cable connection upload and download vary around 30 KBps . i think the whole thing depends on the ISP`s
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
20-08-2005, 07:26 PM
Commander in Chief
He's talkin bout uploads m8,not downloads...and only of BSNL in general...
Harsh J
www.harshj.com
20-08-2005, 07:41 PM
well upload is normally les but abt downloads i dont agree with 2 factor thing.
i have a 128 kbps connection n i get 107-112 normallly.
one more query, is it pos to have a 132kbps connection on a 128 kbps line. i have da scrreenie of dat for my connection. it was a zdnetindia.com speed test.
20-08-2005, 08:19 PM
Oh yeah a little +/- from the original speed is ok! Well, im on sify 48 kbps, but it get around 80 kbps! And one time for around 1 hour, i got 800 kbps! Hehe. Depends on your ISP actually.
20-08-2005, 08:42 PM
@rajat22
Well,the reason is simply bcoz BSNL DataOne is based on ADSL (Asymmetric DSL) where Downloads and Uploads take place at different speeds.
Find out more on ADSL at http://howstuffworks.com
Hope it helps
Adios
\"Cogito,Ergo Sum\"
20-08-2005, 09:11 PM
I have airtel adsl connection, but my upload and download are the same. It all depends on the isp ultimately.
Who taught you this formula?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
20-08-2005, 10:27 PM
QwertyManiac, do you think this is YIM? U got a cool avatar, now I think you will have a cool user badge also.This is the final warning, next time if I see you spamming, then a cool badge will find your way.
@whim_gen, also all ADSL ISP's dont limit the uploads.
Thread cleaned
20-08-2005, 11:06 PM
hi rajat22
can u give me da link which u have used to count ur uploads/downloads speed.
i cant find a right service to check my speeds, i was previously using zdnetindia, which is down rite now.
20-08-2005, 11:19 PM
21-08-2005, 07:45 PM
let me clear the air. As whim_gem said that dataone runs on a Assymetric DSL connection the download/upload speeds vary and sicne we donwload more than we upload download speeds are much higher than upload speeds. So on a dataone conection we get 200-220 kbps d/l speeds when compared to 40-60kbps connection. I know people who get 60kBps connection on their MTNL line which also follows the ADSL principle but thats more of a SDSL connection,. Even airtel is more of a SDSL connection
Search this Thread |
