Old 20-08-2005, 01:31 PM   #1 (permalink)
Default What is the problem with my PC
Hi
I have a strange problem. My PC suddenly goes dead with only the Green light on Cabinet blinking. Even after I restart, nothing hapnnes except the blinking green LED.
I changed the SMPS with no success. Checked the Reset & powern switch but teh problem persists. It hapens occassionaly otherwise all works fine.
I have a P3 1100 Mhz, with ASUS MB. Can someone throw somelight. I changed OS from Win 2k to WinXp but with no success.
asheet is offline
Old 20-08-2005, 02:23 PM   #2 (permalink)
are u sing any external device other than printer or scanner-- like mobile phone modems,,,
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
Old 20-08-2005, 05:06 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Thats due to overheatin of ur proccy or the cabinet on the whole...
Happens to me sometimes if i sit for more than 6 hrs and without fans,...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-08-2005, 06:33 PM   #4 (permalink)
busyanuj's Avatar
since you tried changing your OS, so you can see that the problem is not related to software. It's a hardware issue.
hmm... smps is also okay.
Does the problem occur after prolonged use of computer only or does it happen at random even when computer has been on for a few minutes only ?
if it occurs every now and then, then get your motherboard checked by a technician.
busyanuj is offline
Old 20-08-2005, 07:35 PM   #5 (permalink)
well i can help u fix this 'cos i have da same problem , absolutely same problem.
before i start i want few questions:
1. does ur comp go off when its start, even in 24 hrs running time?
2. how are u able to start it? is that it goes okay when kept switched on for 5 mins (this is da case wid me)
possiblilties of solution are:
1. problem wid hd: there may be problem with hd detection, give a delay of 2 s from bios.
2. gointo bios n put on "Always on" in POWER category
3. change smps agian and try. 'cos my pc works well when smps is changed.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 21-08-2005, 07:50 PM   #6 (permalink)
even i think its a smps prob
cyrux is offline
- by Krow
