Old 20-08-2005, 01:30 PM   #1 (permalink)
saptak
Posts: n/a
Default Installing IIS 5 <EMERGENCY>
Wen i tried to install IIS 5 (5 times already ) on win Xp Pro sys, I get prompted for username and paswd wen i type localhost..
Well i have prev worked with IIS wen i had a PHP/Mysql assignment but i had uninstalled IIS after dat was over. Cud i have done smthng den to cause dis???
PLz Help!!!
Old 21-08-2005, 01:01 AM   #2 (permalink)
String Phreak
mediator's Avatar
Awwww i sympathise with u!
Ur PC's fine IIS too is fine! U didnt need to install the hell 5 times!
U R getting password prompt bcoz ur using firefox or opera probably -> use IE6 !
Since ur using a microsoft product u should test it on another microsoft product coz IIS and IE6 are both microsoft's ****!
mediator is offline
Old 21-08-2005, 01:09 AM   #3 (permalink)
yes. hez right. well i haven't tried them wid firefox n used IE n used it well for all the time.
brb if ur prob gets solved. i gotta know.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 21-08-2005, 01:55 PM   #4 (permalink)
saptak
Posts: n/a
Just to be accurate, it is IIS 5.1, not 5 and html files r working fine, just d ASP ones r'nt.
Now, i was using IE6 itself.
i.e. why its such a pain in d *** problem.
I'm doing all this to get my ASP.net s*** up and runnin. I googled dis also n checked dat dis cud be caused by prior installation of Visual studio and Visual .NET framework.
WHAT D HELL IS GOING ON??????
Old 21-08-2005, 03:53 PM   #5 (permalink)
String Phreak
mediator's Avatar
Well check ur IIS settings then, enable anonymous access!
And i dont thiink Visual studio is cozing any problem
mediator is offline
Old 21-08-2005, 09:19 PM   #6 (permalink)
saptak
Posts: n/a
as i said i have googled and read suggested solutions to probs like this on many forums and anonym access was a probable punga ..
been dere done dat.................. but to no awail!!!
Wat Nxt???
Old 21-08-2005, 11:27 PM   #7 (permalink)
String Phreak
mediator's Avatar
hmm...terrible
U did 5 install can do another?
Try to do a clean install this time!
Remove the IIS and then do a clean install!
If u dont know how to clean install then google a bit!
mediator is offline
Old 22-08-2005, 11:40 AM   #8 (permalink)
royal's Avatar
Maybe u cud try this ...
Goto "Internet Information Service" > "Default Web Site" > right click > "Properties" > "Directory Security" tab > click on "Edit" button of "Anonymous Access and authentication control" > check "Anonymous Access" > click on "Edit" > Uncheck "Allow IIS to control Password"
Restart IIS
royal is offline
- by Krow
