Old 19-08-2005, 11:15 PM   #1 (permalink)
Default Taskbar problem
Can't do anything from the task bar.Nothing works from start button,right clicking to maximising anything.Whats the reason?
ra_sriniketan is offline
Old 20-08-2005, 06:49 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try repairin ur installation, or jus install an sp again or fresh and try...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-08-2005, 07:07 PM   #3 (permalink)
expertno.1's Avatar
hye hey press
windows key +r
type
msconfig
selsect "normal startup"
if this doesn't solves the prolem then reinsatll xp
or try to get or make a new account in xp
expertno.1 is offline
Old 20-08-2005, 07:14 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Is it like taskbar has become freezed???
Try one thing!
Start ur windows in Safe Mode and check whether the taskbar problem still exist, cauz its possible that some s/w is forcing taskbar to remain freezed.
Then type msconfig in Run dialog box and goto: Startup tab, and see is there ne undesired s/w listed in the list.
If its there, then simply uncheck it and restart ur windows in Normal mode.
May be it can work...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 20-08-2005, 07:45 PM   #5 (permalink)
reinstallin can fix prob for sure. nd its very much pos any sware is unable to load itself so the problem.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
- by Krow
