Old 19-08-2005, 06:57 PM   #1 (permalink)
Default whichone to choose ddr or ddr2
hey,
just tell me, where to go ? my 2 ways are
1) 2 gb of ddr 400 mhz
2)1 gb of ddr2 533 mhz
as i already said my mode of transport is multimedia work like (maya,combustion,photoshop,flash).just help me ...........
vraja4u is offline
Old 19-08-2005, 07:51 PM   #2 (permalink)
siriusb's Avatar
Take the ddr400 2GB option. DDR2 has a bit of higher speed but is compensated by its higher latencies. And 2GB shud help u out in grafx.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 19-08-2005, 10:42 PM   #3 (permalink)
I agree.
geekysage is offline
Old 19-08-2005, 11:34 PM   #4 (permalink)
sidewinder's Avatar
i agree too
Bombina rocks
sidewinder is offline
Old 19-08-2005, 11:49 PM   #5 (permalink)
hcp006sl's Avatar
Good suggestion.
If you are not satisfied with DDR, try RD. If your mainboard supports.
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 20-08-2005, 12:22 AM   #6 (permalink)
The Hardware Labs
mohit's Avatar
Originally Posted by hcp006sl
Good suggestion.
i dont suggest going for RD RAM .. it is hardly available in India and the price is just too steep. Go for DDR 400 Mhz 2 gb , it will be more than sufficient for graphics intensive work.
mohit is offline
Old 20-08-2005, 06:00 PM   #7 (permalink)
Uhmm , well , yeah !
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 20-08-2005, 06:14 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
I too agree with siriusb...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-08-2005, 07:42 PM   #9 (permalink)
Resident Weapons Expert
zombie's Avatar
These chips are the next generation of DDR SDRAM memory. They are mounted on 240-pin DIMM modules, can operate at higher bus speeds and have a capacity to hold 256 Mb to 2 GB of memory. DDR2 has twice the latency of DDR but delivers data at twice the speed of DDR, theoretically performing at the same level. But it'll cost lot more. I think its always better to go for more amount of marginally slower memory rather than faster but less memory. For graphic intensive applications my vote goes to 2GB DDR @ 400MHz.
Stalk, Strike, Survive.
zombie is offline
Old 20-08-2005, 07:48 PM   #10 (permalink)
ya definately go DDR400 ram
www.guessthelogo.blogspot.com
harshagarwal is offline
Old 20-08-2005, 07:54 PM   #11 (permalink)
zombie's Avatar
Moreover DDR2 compatible mobo will be quiet a bit costlier than a DDR compatible mobo. Add to this the higher cost of DDR2 and it will escalate the overall cost of your rig.
zombie is offline
Old 20-08-2005, 08:53 PM   #12 (permalink)
Good suggestion.
RD = dead as a dodo!
Keith Sebastian is offline
Old 20-08-2005, 09:02 PM   #13 (permalink)
zombie's Avatar
Cant even get a module in the neighborhood for RD. My buddy was stuck with 2X256MB RDRAM module. One went BOOM, so instead of wasting time and money for RDRAM, he got a new AMD mobo/CPU combo. So much for as good as dead RDRAM. I think he's not alone in this boat.
zombie is offline
- by Krow
