Old 19-08-2005, 03:09 PM   #1 (permalink)
expertno.1's Avatar
Default Renamer
i ahve a lot of midi files but not of proper names
i want to change the names of them to like
1.midi
2.midi
3.midi
4.midi
5.midi
and so on
how can i do this at a click
expertno.1 is offline
Old 19-08-2005, 03:34 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
U want to change file names ?
Press f2 to rename a file at a time...
Try these too...
http://www.mediachance.com/free/renamer.htm
This is a cool one :
http://www.123renamer.com/faq.htm (to use , instructions)
http://www.123renamer.com/download.htm (to download)
More :
http://www.snapfiles.com/freeware/sy...ilerename.html
Hope it helps !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2005, 03:41 PM   #3 (permalink)
http://www.1-4a.com/rename/download.htm
the concept is called batch rename.
when u want to count 1,2,3 u need to use the "ADD LEAD" field.
hope this helps as its universal for any renamer software. XP has no integrated feature. Phostoshop has it but only for images.
Renamers have wide varity of options to rename. so they r worth downloading.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 19-08-2005, 05:45 PM   #4 (permalink)
expertno.1's Avatar
that 123renamer is not free
any free and best one ?
Old 20-08-2005, 12:24 AM   #5 (permalink)
Thor's Avatar
U cud Try Flexible Renamer .
Link : http://www.buzzys.net/flexible.html
Changing the name of a large group of files individually can be a real pain in the butt. You may find that files transferred from your digital camera to your hard drive are in order, but their names consist of a group of letters and numbers that usually don't identify the pics themselves. Plus, after you transfer the files from your camera and delete them from it's memory, the next set of pics taken with your camera can have the same name as the files you've just uploaded. Different pictures, same name!! Flexible Renamer by Naru will take a batch of files and give them the name of your choosing. Here, take a peek and dive in:
Flexible Renamer is easy to use. Just pick a directory where your files are on the left, select the work that you want to do to your files from the middle, and check in the right window to make sure that your files are going to be renamed and directed the way you wish. Click 'Rename' and volia, your finished. The program is really fast too as I have changed up to 175 photo file names in one session with a total time used at approx. 15 seconds. As shown, you can change the name in any number of combinations such as the Date Time (default), strings (words that will be on all files), adding numbers to the beginning/end of any string plus more. You can set the number of digits in the filename (excellent for naming over 100 pics to keep them in order, such as 001!), and even the start number. This is very handy if you are combining bunches of pics from different directories to one directory. The window can be expanded to show you quite a bit of information including a list of the files after they have had their names change. The column's are adjustable, as are the individual windows for each specific area.
Along with all of the above goodies, Flexible Renamer can also copy and rename to another folder, has an undo feature, allows the use of wildcards, and has a multiple file filter. Here's a pic of the 'context menu option' window with all of the possible settings:
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 20-08-2005, 12:31 AM   #6 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Hey mods look at expertno.1 Posts:1402 and joining 16 May 2005 See above double posts and see that how he has managed that count i.e. by double posting. Please check such members and take action against them. Post reported to mods.
navjotjsingh is offline
Old 20-08-2005, 06:09 PM   #7 (permalink)
Commander in Chief
Doublies ?
Where ?
Dude, i guess u see all the past posts no of expertno1 and u will know bout his thirst of tech...
Harsh J
www.harshj.com
Old 20-08-2005, 06:24 PM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Is there ne reward for the members with highest posts?
Its a very common problem of double posting...
It happenes due to slower net speed.
Many times we click on Post Reply button and nothing happens, so we click on it again, but actually that post has already been posted.
Thats why it causes double post problem.
And I think there is an option of Recount the posts and many things in Admin CP.
And I'm sure that mods / admin make use of it time to time...
SO just Chil Chil
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 20-08-2005, 06:26 PM   #9 (permalink)
Commander in Chief
If they give away awards for postin, then they require 1000TB Hdd space co then all the competition starts...
P.s.@expert - Is ur problem solved ?
Harsh J
www.harshj.com
Old 20-08-2005, 06:34 PM   #10 (permalink)
Microsoft MVP
Very true!!!
Thats what i wanted to tell here.
Why ne1 will want to increase his total no. of posts?
It happens only due to net problems, like speed...
Old 20-08-2005, 07:18 PM   #11 (permalink)
expertno.1's Avatar
are yaar Vishal you are right !
i was on a 14.4 k connection and the net was hanging so i couldnot get whether it has been psoted or not
but since thor psoted so i cannot dlete my psots coz i dnt have any powers na !!!!
Old 20-08-2005, 07:19 PM   #12 (permalink)
Commander in Chief
U can delete ur posts in the edit mode mate...
Our posts ,our rights...
Harsh J
www.harshj.com
Old 20-08-2005, 07:22 PM   #13 (permalink)
Microsoft MVP
How can u delete ur posts in Edit mode?
There is no option to delete the posts.
I can only see the Delete button on my last post, which must be the last post in that thread.
If i try to delete some posts, after which som1 has posted his post, then it gave ERROR, like U can't delete already answered post or something like that...
Old 20-08-2005, 07:25 PM   #14 (permalink)
Commander in Chief
Get into edit (1st time only)
see the place of checkboxes and u will find an option there......
P.s.nobody shu've posted ahead of u...
Harsh J
www.harshj.com
Old 20-08-2005, 07:29 PM   #15 (permalink)
expertno.1's Avatar
yeah but that is edit option and not deletion option dude
Old 20-08-2005, 07:35 PM   #16 (permalink)
Microsoft MVP
Thats what I mentioned in my previous post.
We can delete only those posts which r the last post in the thread.
We can't delete posts, if some1 has posted ahead it.
PS: Mods / Admin, why this restiction has been set? Pls allow us to delete our posts, But members can be restricted to delete the first post of the thread, so that the whole thread can be saved for deletion...
Old 20-08-2005, 11:46 PM   #17 (permalink)
Thor's Avatar
Does This Make any sense.... ???
We r free to post wherever we want unless we break any forum rules..
He meant after His post I posted as a result his post was no longer the Latest one...thus there was no option to delete his post...
Thor is offline
Old 21-08-2005, 12:31 AM   #18 (permalink)
allright. relax buddies. we shd be making the forum a cool place to b instead of posting something against somebody. well if anybody has got any damn problem against anybody, he/she needs to report it as PMs and not as postings in a query.
'cmon these have to be kept in mind. everybody. and chill, digit has enough space to withstand postings, be it 1400 or 5000. right? and about how appropriate a post is, mods have always their eyes open n they have spl badges. so evybody chill.
PriyaRanjan Singh
Old 21-08-2005, 08:04 AM   #19 (permalink)
expertno.1's Avatar
yeah thanks
and about my problem thast solved
and about Navjot...he has posted a minimum of 6 times about my posts coz my posts average is 15/day
he thinks i am posting twice and thats why heis complaining
relax yaar
complaining will not make you a mod
- by Krow
