Old 19-08-2005, 01:21 PM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default A HUGE Problem !!
Recently I have started facing a problem in my PC. I can log on to the net but whenever an application uses the net, an error screen opens. For example in Internet Explorer, when I click on "Details", it shows:
IEXPLORE caused an invalid page fault in
module <unknown> at 0000:0078ad60.
Registers:
EAX=0078ad09 CS=016f EIP=0078ad60 EFLGS=00010216
EBX=0000277a SS=0177 ESP=01d2f720 EBP=01d2f770
ECX=01d2f730 DS=0177 ESI=0078ad81 FS=35d7
EDX=c15ad810 ES=0177 EDI=01d2f760 GS=0000
Bytes at CS:EIP:
80 af 78 00 80 af 78 00 20 2d 78 00 c4 95 44 00
Stack dump:
00000177 76003481 01d2f730 0078ad80 0078ad80 76002881 00000000 00771d6c 007718c0 760029ff 00771c60 01d2f760 00770470 01d2f8f8 ffffffff 0077047c
Plz help me regarding this issue.
Thankx in advance !!
Old 19-08-2005, 01:31 PM   #2 (permalink)
MVP in VC++
Which OS u r using and if it is XP have u installed latest service packs.i.e sp2
cvvikram is offline
Old 19-08-2005, 02:08 PM   #3 (permalink)
Just Do It
Charley's Avatar
Chck this link
http://www.colba.net/~hlebo49/erriexpl.htm
I'd had these prob bfore and I formatted my drive and reinstalled the entire OS again .... It worked perfect after that.
Charley is offline
Old 19-08-2005, 02:58 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Thats Extreme, but try reinstalling internet explorer from the components menu...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2005, 03:10 PM   #5 (permalink)
exactly. i agree.
there is some prob in IE module. reinstall it (may be newer ver)
and if u havent tried Mozilla Firefox, give it a try to know which one suits u. a must try browser.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 19-08-2005, 04:03 PM   #6 (permalink)
Commander in Chief
Sure m8, how can i forfet FireFox ?
Here U go :
http://ftp.mozilla.org/pub/mozilla.o...up%201.0.6.exe
Harsh J
www.harshj.com
Old 19-08-2005, 06:28 PM   #7 (permalink)
String Phreak
mediator's Avatar
Still stuck up on IE use opera or firefox!
mediator is offline
Old 19-08-2005, 06:51 PM   #8 (permalink)
siriusb's Avatar
Doods, why bring in the fox here? He must have his reasons to use IE. And that is besides the point.
Try this MS article:
http://support.microsoft.com/default...;en-us;Q302463
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 19-08-2005, 07:39 PM   #9 (permalink)
vignesh's Avatar
If you are using 98 download ie6sp1.
vignesh is offline
Old 21-08-2005, 03:56 PM   #10 (permalink)
nipun_the_gr8
Posts: n/a
Default Re: A HUGE Problem !!
It means that the error occurs whenever I try and use ANY application that uses the net (it also includes Firefox etc.)
Old 21-08-2005, 03:58 PM   #11 (permalink)
nipun_the_gr8
Posts: n/a
And I am using Windows 98 as well as XP Pro. SP2 edition but the problem is only occuring in Windows 98.
Old 21-08-2005, 04:42 PM   #12 (permalink)
expertno.1's Avatar
post a hijack this log here
expertno.1 is offline
- by Krow
