Old 18-08-2005, 11:23 PM   #1 (permalink)
Default NTFS TO FAT32
I have win 98 and win XP running on cFAT32) and dNTFS) respectively.How do I convert my d: to FAT32 ???????
Everyone is prone to fear.One who can dominate this fear is brave.
abhra_life is offline
Old 18-08-2005, 11:36 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
hmm a format is needed... but Partition Magic may b able to do it with out a format....
well in case of format.... follow this guide...
  1. Start the computer by using the Windows XP CD-ROM or the Startup disks.
  2. Go to Recovery console by Pressing R (when asked)
  3. In Recovery Console, specify the appropriate installation, and then log on by using your Administrator password.
  4. Type map, and then press ENTER.
  5. Note the drive that you want to reformat. The drive letters may be different in Recovery Console from what they are in Windows XP.
  6. Type format x: /q /fs:fat32, where x is the letter of the drive that you want to format and FAT32 is the file system that you want to use, and then press ENTER.
  7. Type y and then press ENTER to confirm your choice. When the formatting process is finished, type exit and then press ENTER, to restart the computer.
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-08-2005, 12:25 AM   #3 (permalink)
well i dont think u can conver ntfs to fat.. fat can be converted to ntfs butnot vice versa
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
Old 19-08-2005, 12:39 AM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Partition Magic will be the best option...
I think It can convert NTFS partition into FAT32.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-08-2005, 01:01 AM   #5 (permalink)
busyanuj's Avatar
naah KnightRider, it seems that you're prolly misinformed about this.
A simple format option /fs: is all that is needed to convert fat to ntfs and vice-versa. you can specify the option to be ntfs or fat32.
busyanuj is offline
Old 19-08-2005, 01:43 AM   #6 (permalink)
Rebooting
@Vishal Gupta & @busyanuj
i never used Partition magic b4.... so have some question... questions r......
will Partition magic install in windows XP (Drive D) can b able to Convert Drive D to FAT32 from NTFS??
& when install in windows 98 SE will it b able to detect NTFS drive??
& after converting will windows XP b able to boot in (without reinstall..)..??
rebooting
ChotoCheeta.com
Old 19-08-2005, 08:13 AM   #7 (permalink)
expertno.1's Avatar
well use partition magic
it will do it
also
ranish partition manager
expertno.1 is offline
Old 19-08-2005, 09:14 AM   #8 (permalink)
MVP in VC++
Yup can partition magic is good and it converts both ntfs to fat32 ad vice versa
cvvikram is offline
Old 19-08-2005, 11:25 AM   #9 (permalink)
cybermanas
Posts: n/a
The same answer : Partition Magic is your best bet when it comes to managing partitions inn any windows operating system.
Old 19-08-2005, 01:27 PM   #10 (permalink)
The BEST & EASIEST way tp partition hard disks is using Linux Live CDs. They come with an EASY GRAPHICAL partitioner wich makes partitioning like child's play! Nothing more than point n click!
If u dont believe me, use the SimplyMepis Live CD or PCLInuxOS Live CD....and u can do whatever u want with ur partitions!
coolblue is offline
Old 19-08-2005, 01:31 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
but tis costly, partition magic's costly...
Hows ranish interface ?
U r talkin bout resizing NTFS parts and not conversions without format...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2005, 03:56 PM   #12 (permalink)
well go for prtition magic 8. the latest version which is really nice in interface n makes things easier.
interconversion is posible but u cant change d:\ by installin PM on d:\ itself (i m not sure, but i hope so)
cosu r changing the filesystem, so u cant expect it to be working well simultaneously. what say?
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
- by Krow
