Old 21-09-2004, 11:02 PM   #1 (permalink)
Default Help - Kaspersky - Urgent !!! BATTY
I downloaded Kaspersky (Latest Version) Personal Antivirus.
It worked properly for a day or two ...
Then suddenly ... every minute or two or wen i open My Computer or any other Windows Explorer ... it says
and sorry for the image link as im trying it for the first time
Im using Windows XP SP1
Mozilla Firefox 1.0 PR (as this error eats my head wen i try to open IE 6)
I downloaded Kaspersky based on the findings of the forum and BATTY ...
so evryone here ... plz help me out !!!
talrejaharish is offline
Old 21-09-2004, 11:10 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
The file relates to missing Script Blocking service of Norton Antivirus ... Uninstalll NAV completely to get rid of the error ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 21-09-2004, 11:27 PM   #3 (permalink)
Default !!!
Norton Antivirus 2003 is fully uninstalled !!!
My Yahoo! Messenger 6.0 is also giving me problems !!!
cant see watevr i type or watevr others reply !!!
tried downloadin it all over again !!!
But the main thing is this error occcuring without Norton Antivirus !!!
help !!
want me to post the HijackThis Log File for you ????
Old 22-09-2004, 01:31 AM   #4 (permalink)
a bad Norton Uninstall
http://www.avp.ch/E/faq.stm#scrauth
for a proper uninstall
http://service1.symantec.com/SUPPORT...01061911223206
Slackware : The only GNU/Linux distribution developed on The KISS Principle!!!
Have you been kissed yet? : Get Slack
id10t is offline
Old 22-09-2004, 02:14 AM   #5 (permalink)
Yeah .. Check the link posted by id10t ...
Old 23-09-2004, 11:46 PM   #6 (permalink)
Default UMMM
Problem not solved yet .... same error !!!
Any detection methods (HijackThis) etc .... using real time protection of Kaspersky personal ...
did watever was needed by Norton !! Download their
RNav2003.exe
file and executed tat also !!!
What to do ????
dont wanna resort to my last option .. :roll:
call my engineer and he will just Format my C drive ... so help out asap !!!
Old 24-09-2004, 12:43 AM   #7 (permalink)
Ok Here is the solution to your problem.
[Edit] Ok .. I think the solution posted there is too much confusing .. I m uploading the registry patch to fix the problem ....
Watch this space ..
[Edit]Ok download the fix from Here ... Extract the file and double click on the Reg file to merge it to your registry ...
Old 24-09-2004, 12:51 AM   #8 (permalink)
you didn't follow the first link. isn't it?
look man the problem is that when you install Norton, it takes over java script handling and blocks the scripts that might cause harm to your PC thus it takes over jscript.dll with a proprietary file namely scrauth.dll
now you have uninstalled Norton and scrauth.dll is gone but since the java script handling is still allocated to scrauth.dll, kaspersky shows you error about the same. what you need to do is give the control to kaspersky and restore that registry value. for doing that you need to follow the first link...now if you are not good with registry editing then i would recommend asking one of your tech savvy friends to do it. else...a format will be in order.
[EDIT]looks like someone beat me to it [/EDIT]
id10t is offline
Old 24-09-2004, 11:37 PM   #9 (permalink)
umm ... unfortunately ... problem nt solved yet ...
Batty :
the first link u gave
gave a too confused method ... yet i went thru it and found the necessary changes to be made to the regedit .... but it aint working yet ...
the second link
opens this same page again ... can u plz check the link and reply asap ...
thnx
and IdIot ....
u talking bout this first link wen u say this ????
i am a bit familiar to Regedit in Windows ... so i tried it ...
and now the second link doesnt work so its not my falut ...
[EDIT]looks like someone beat me to it Wink[/EDIT]
so plz reply asap ...
thnx !!!
Old 25-09-2004, 12:02 AM   #10 (permalink)
Ok .. I think Freewebs are playing smart ..
I have uploaded it here courtsy Anand ... Download it and merge it to your registry ...
Old 25-09-2004, 12:18 AM   #11 (permalink)
hey,
Batty and Anand ul r too good !!! must say ...
N a word to the forum moderators also ...
GreAt Work ...
but there is one more thing left ....
The error stopped ....
but now it shows up the same thing but this time with
VBScript error
can i request and get an entry to rectify that also ???
it would be just too good !!!
plz plz plz plz plz plz plz plz plz plz plz
thnx thnx thnx thnx thnx thnx thnx thnx
Old 25-09-2004, 12:52 AM   #12 (permalink)
Ok ... Here is the VBScript Fix ... Again courtesy Techlogy.Net ... ...
Old 25-09-2004, 08:19 PM   #13 (permalink)
thats it ,,,, finally my thing is done
that ERROR stopped occuring ...
now if ull cud solve ma prblem of that installation of softwares thing .... it wud b grt ....
plzz plzz plzz
thnx thnx thnxx
Old 26-09-2004, 12:36 AM   #14 (permalink)
What ...? That error is still prevailing ...???
Old 26-09-2004, 01:11 AM   #15 (permalink)
the Post of mine relating to my Adobe Premiere Installation and some other software is still unattended .... i mean unsolved ...
thats wat i would like to get solved asap
plz plz plz thnx
harish here
- by Krow
