Old 18-08-2005, 06:13 PM   #1 (permalink)
Default connecting computers????
hi,
i have two set of computers(10 at max each) located at around 120 mts distance. i also have this fibre obtic cable. since the distance is more, i want to use this fibre optic cable.
all the ports are of 10/100 MBPS (and i think this is more then enough). is there any way i can use this 10/100 MBPS switch (2 Nos) to connect via Fibre optic cable rather then normal CAT 5/6 cables??
pls help
taken is offline
Old 18-08-2005, 06:44 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Check tis :
http://www.techoptics.com/pages/Fibe...0Networks.html
Says tis vailable for gigbit (i didnt read but scanned)
Harsh J
www.harshj.com
QwertyManiac is offline
- by Krow
