Old 18-08-2005, 05:02 PM   #1 (permalink)
bharat_r's Avatar
Default ServicePackFiles
When I was going through my Windows directory I found 2 folders containing almost the same files totalling to a size of 1 GB:
C:\WINDOWS\ServicePackFiles\i386
C:\WINDOWS\Service_Pack_Files\i386
I'm having
Windows XP Professional Edition Service Pack 2 build 2600
are those folders necessay or can I delete them to free up the 1GB space?
bharat_r is offline
Old 18-08-2005, 05:05 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
These folders r necessary if u'll want to uninstall these service packs in the future.
If u delete these folders, nothing will happen but u'll not be able to uninstall service packs ever!!!
So u can safely delete them if u don't want to uninstall service packs. And i think no1 will want to uninstall these Service packs...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 18-08-2005, 05:10 PM   #3 (permalink)
bharat_r's Avatar
Thanks,I'm going to delete them.
1GB is quite some space.
bharat_r is offline
Old 18-08-2005, 05:51 PM   #4 (permalink)
Thor's Avatar
Hey ! Cool ! Me Gonna Give My HDD 1 GB More Breathing Space !
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 18-08-2005, 11:28 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
hmm... but when u install from SlipStream XP SP2 installetion disk.... there isnt that option of Uninstalling SP2... so no question of tht 1GB taken up.... lol... so i have a advantage there....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-08-2005, 08:56 AM   #6 (permalink)
expertno.1's Avatar
these are the service pack files
u cna delete them surely
expertno.1 is offline
Old 19-08-2005, 09:04 AM   #7 (permalink)
MVP in VC++
These are the sp2 files which are created when installing the sp2 ...i have deleted them...no probs...
cvvikram is offline
Old 19-08-2005, 11:11 AM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well,
@saurav_cheetah,
U can save more space by turning off or controllin ur system restore space....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2005, 05:01 PM   #9 (permalink)
when we install service pack, first the files r extracted to that folder n installed from there. once installed we can delete them (as they r nothin more than executables).
about installation may be using the same cd which we use to install will definitely give us options like "INSTALL,REPAIR,REMOVE" when used again.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
- by Krow
