Old 18-08-2005, 03:59 PM   #1 (permalink)
Default hELP me regarding Computer!
well..can u help me ..actully my windows system randomly restarts and after restarts it shows something like..recovery of one registry file using alternate copy and recovery was successful...it happens very frequently...i mean sometime it happens within half an hour
so what shud i do
i dont wana reformat the drive nor i do wanna reinstall my windows
abhinav is offline
Old 18-08-2005, 04:31 PM   #2 (permalink)
Disable automatic restart first.
My Computer>Properties>Advanced>Startup & Recovery>Settings>Uncheck "Automatically restart" if its already been checked.
Also could you post a near exact error message or information you get while this error occurs.It would help for sure.
www.Oobertech.net
digen is offline
Old 18-08-2005, 04:45 PM   #3 (permalink)
fanatic's Avatar
Default what is this automatic restart fntion in the "startup....
what is this automatic restart fntion in the "startup and recovery" for?
http://xforum.hugetop.com
Tutorials, Whitepapers, Beginner articles, How tos and Getting started Tutorials. All information you need about Computers, Ethical Hacking, Security, Web, Web Programming.
fanatic is offline
Old 18-08-2005, 05:21 PM   #4 (permalink)
When you shut down your Windows XP-based computer, your computer may restart instead of shutting down, and you may see a blue screen for just a moment before the computer restarts.
The behavior can occur if the following conditions exist:
You have "automatically restart" selected. (Press WinKey-Break, or (Start/Run/Sysdm.cpl),  Advanced Tab, Start Up and Recovery/Settings/System Failure/Unmark "Automatically Restart"/Ok/Ok.
http://www.kellys-korner-xp.com/win_xp_restart.htm
www.Oobertech.net
digen is offline
Old 18-08-2005, 06:43 PM   #5 (permalink)
thanks but this also doesnt solve my porblem
abhinav is offline
Old 18-08-2005, 07:58 PM   #6 (permalink)
I never said it would solve or was a solution to your problem.It was just the start to find out the exact error message or information regarding the registry problem you are facing.
Now the next time you face a critical error your system wont automatically restart if you followed my above post[this is true under majority of cases].This would inturn enable you to take notice of any BSOD,Stop Error Messages & write it down on a piece of paper & post about it here.
Perhaps I wasnt clear earlier but I hope I'm crystal clear now.
www.Oobertech.net
digen is offline
Old 19-08-2005, 11:30 AM   #7 (permalink)
LOOK OUT IF U INSTALLED SOME SOFTWARE OR MADE SOME HARDWARE CHANGES AFTER WHICH THE MACHINE STARTED GIVING THE PROBLEM.UNINSTALL THAT SOFTWARE. PATCH UP UR COMP WITH LATEST UPDATES AND TRY INSTALLING THE LATEST VERSION OF THE SOFTWARE.THIS MIGHT SOLVE UR PROBLEM BUT SURE GET THE EXACT ERROR MESSAGE OR NEAR EXACT.DIGIT PEOPLE WILL SURE HELP U
Light is faster than sound.thats why some people appear bright till you hear them speak
drsood123 is offline
Old 19-08-2005, 04:02 PM   #8 (permalink)
adding error msgs really help u solve probs efficiently. read 1st thread in QnA "How to ask question?" for more stuffs like dis.
make use of a restore point created manually or automatically some time before, when u think ur comp was workin well. it shd solve ur problem.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
- by Krow
