Old 18-08-2005, 11:38 AM   #1 (permalink)
Traceur
zegulas's Avatar
Default HDD pins broken
Yesterday when i tried to remove the IDE cable from my HDD 2 pins from my HDD came off. Can we fix it or is my HDD now useless?
If yes wat should i do?
zegulas is offline
Old 18-08-2005, 11:42 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
U can get the PCB changed. Will cost around 400-500 bucks.
kalpik is offline
Old 18-08-2005, 12:26 PM   #3 (permalink)
siriusb's Avatar
Some of my friends have had broken pins in their hdd but they found that it still worked. Seems some pins can be broken. But you might've broken all the wrong pins. Better get it checked with the dealer.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 18-08-2005, 04:13 PM   #4 (permalink)
Traceur
zegulas's Avatar
Ya because some r just ground pins. I tried to place the broken pins in their carefully attached the ide cable and it worked
zegulas is offline
Old 18-08-2005, 07:02 PM   #5 (permalink)
@zegulas
I am using seagate hdd(80 gb) for a year now with a broaken pin.
Me too quite amased that time but it is matter of which pin got screwed.
Techmastro is offline
- by Krow
