Old 18-08-2005, 10:07 AM   #1 (permalink)
Default Doubt in SYSTEM MECHANIC...
I'm using Windows XP prof. SP2
I have installed System Mechanic 5.5a recently.
In System Mechanic I saw, it cleans everything and it clean Ad-aware files also.
I have Kaspersky Anti-virus software.
My question is...?
Wheather i have to install any Ad-aware softwares or not?
Is there any problem in System Mechanic?
Please tell me some suggestions...
satya_gen is offline
Old 18-08-2005, 11:20 AM   #2 (permalink)
MVP in VC++
Yes the System Mechanic removes some of the spywares but not all.so better to use the specific softwares like Adware,Spybot etc.
cvvikram is offline
Old 18-08-2005, 12:00 PM   #3 (permalink)
mariner's Avatar
even thiugh sys mech offers a adware cleaning option but none can beat ad aware se and spybot snd. it wud be a good practice to install both ad aware se and spybot and just to be on the safe side also install spyware blaster to give u the best protection.
mariner is offline
Old 18-08-2005, 06:15 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
true. utilities like system mechanic or super utilities, do have spyware cleaners, but they r just there 'scratching the surface'. u must use microsoft anti-spyware or adaware or spybot.
u cud download them at www.download.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-08-2005, 06:18 PM   #5 (permalink)
Thor's Avatar
Yesss.. get an Adware-Spyware cleanr...Iolo's System Mechanics' Cleaner is not that comprehensive.
Best Combination wud be :
1. Lavasoft's Adaware.
2. Spybot's Search & Destroy.
Both r FREE...
To Qwerty Sorry Mate...Was a Typo..
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 18-08-2005, 06:26 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
'BNoth r free'
u mean both r not free ?
or what ?
Even NAV removes Spyware and so does Zone alarm...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-08-2005, 06:55 PM   #7 (permalink)
Mate it will be better if you use seprate adware/spyware remover.
Few options to consider:
1. Spybot's Search & Destroy.
2. Webroot spysweeper.
3. Lavasoft's Adaware
Techmastro is offline
- by Krow
