Old 17-08-2005, 06:30 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default Browser Hijackers : New Kinds !
Browser hijackers have started using a variety of methods to trick the user into installing them, but a growing part of them uses vulnerabilities in
Internet Explorer instead to install completely silent. Since some of
these exploits have NOT been patched by Microsoft yet, this app
provides a temporary solution for these vulnerabilities, by disabling
the vulnerable Windows components. u can check out this utility 'BugOff'
Recent browser hijackers have also started using ADS to hide their files,
and very few anti-spys detect this. Alternate Data Streams (ADS) are
pieces of info hidden as metadata on files. They are not visible in
Explorer and the size they take up is not reported by Windows.
Use this tool 'ADS Spy' to find and remove these streams. this app also
displays legitimate ADS streams. Don't delete streams if you are not
completely sure they are malicious!
http://www.spywareinfo.com/~merijn/downloads.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-08-2005, 06:46 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
buddie, u sure do know a lot of viral buisness goin on, tell me whether u have been infected several times or what ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2005, 09:34 AM   #3 (permalink)
expertno.1's Avatar
@anad
you look serious
expertno.1 is offline
Old 19-08-2005, 01:55 PM   #4 (permalink)
Commander in Chief
Shudnt anand get a brainiac on viral info?
Harsh J
www.harshj.com
Old 20-08-2005, 12:00 AM   #5 (permalink)
anomit's Avatar
O yeah ?!
No intention of flaming but brainiacs acknowledge the source of the material.
Thanks to ImageShack for Free Image Hosting
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 21-08-2005, 05:47 PM   #6 (permalink)
Default Hijacked Browser
I really worried about this hijacking. Even if u have "about:blank" as home page ii IE, you will get hijacked site. Because they already hijacked your "about:blank".
What to do? I tried many adremoving software. But of no use.
Luckily I got one FREE softwre "CCleaner". I installed it and cleaned temporary and registry. Surpised!!! Hijackers arrested? or ran. May be entered ur PC???? Beware of Hijackers. If u r attacked by them try "CCleaner". It is available FREE at www.ccleaner.com
Ofcourse, now I have installed "Browser Hijack Retaliator" provided in this Digit CD. Yet to know about it's positive use.
Srinivas Natekar
natekar is offline
Old 21-08-2005, 06:01 PM   #7 (permalink)
Commander in Chief
K bout the brainia, but atleast he's well informed isnt he ?
Harsh J
www.harshj.com
Old 22-08-2005, 12:18 AM   #8 (permalink)
swatkat's Avatar
Spywares and Hijackers which use ADS are here from eons. ADS is available only in NTFS systems.
Popular tool called Lavasoft AdAware detects and removes these kind of malwares.
http://swatrant.blogspot.com/
swatkat is offline
Old 22-08-2005, 11:58 AM   #9 (permalink)
mariner's Avatar
use firefox with the ad bloc plugin. kinda good. and dont forget to run spybot and ad aware regularly.
mariner is offline
Old 22-08-2005, 08:42 PM   #10 (permalink)
anandk's Avatar
thanx for ur sentiments guys.
but let me tell u, i aint no brainiac material.
i just share what i learn !
i have already mentioned the source > spywareinfo site. pls check out my original post ! anomit, i think has mentioned different sites. nice of him to add more inputs.
natekar : set ur homepage as about:blank thru internet options, and then LOCK IT. if u r using spybot or spysweeper or ms anti-spy or winpatrol, etc; they have these options. ur homepage will remain safe.
Microsoft® MVP
anandk is offline
Old 23-08-2005, 01:09 PM   #11 (permalink)
anomit's Avatar
Using AdAware to detect ADS screenshot:
anomit is offline
Old 23-08-2005, 03:48 PM   #12 (permalink)
GameAddict's Avatar
ADS is a feature of NTFS file systems.So if you have FAT32, it won't affect you. Also scanning tools are available to reach and clean ADS files.
GameAddict is offline
Old 24-08-2005, 09:04 AM   #13 (permalink)
Is it good running a lot more spyware detectors.
I currently use Webroot spysweeper, Spybot SnD, AdAware, Spyware doctor, Spyware blaster, Malware scanner, Trojen remover, Safe XP, Anti tracks, Browser hijack retaliator, Hide IP platinum, MS Antispy, XSpy, and The Computer security tool, Along with Windows XP SP2 patched with Autopatcher June.
Should I add ADS spy and Bugoff to my list.
My file system is NTFS and I cant do without that since I have to Compress files to save diskspace still without wasting time.
Also NTFS is meant to be more secure than FAT32. I use encryption technology to secure my personal files. FAT32 cant do it with out additional softwares.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 24-08-2005, 12:39 PM   #14 (permalink)
anomit's Avatar
Nothing wrong with that but never try to run two firewalls or antivirus programs together. They are sure to cause conflicts.
Having quite a few of them i.e. anti-spywares actually help your cause.
anomit is offline
- by Krow
