Old 21-09-2004, 06:00 PM   #1 (permalink)
Default Configuration needed
Guyz/Gals,
I wanna assemble a new PC for 30,000 ....... can anybody suggest a good configuration? Is AMD 64 a good choice?
Duty is Heavier than a Mountain, Death Lighter than a Feather....
raghu_mark is offline
Old 22-09-2004, 09:33 PM   #2 (permalink)
m31
What do you plan to use it for ?
If you are going to use it for gaming then you might not be able to fit in good gfx card in this budget with AMD 64.
m31 is offline
Old 22-09-2004, 10:03 PM   #3 (permalink)
search the forum
ull find enuff threads for ur needs/budget
No Mercy, No Limits.
theraven is offline
Old 23-09-2004, 12:42 AM   #4 (permalink)
if u want a comp for 30000 heres a config.
intel 2.4 ht }
intel 865 m/b } 11000
512 hynix Ram 4800
sony cdrw 1600(white)
sony dvd rom 2100
80gb seagateHDD3500
FDD 280
Cabinet 1050
17" flat Samsung 8300
total 32600
Happy computing 8)
Happy Computing :lol:
krishnathelord is offline
Old 23-09-2004, 12:43 AM   #5 (permalink)
gxsaurav
Posts: n/a
Check my threads
Old 23-09-2004, 09:48 AM   #6 (permalink)
Thanks for the Replies .... I would like to go for a AMD processor and a Moderate Gaming Machine is what i desire.
Can u Guyz/Gals help me on this?
- by Krow
