View Poll Results: Whose mobile products are the best?
Nokia 9 90.00%
Sony Ericsson 1 10.00%
LG 0 0%
Motorola 0 0%
Samsung 0 0%
Alcatel 0 0%
Voters: 10. You may not vote on this poll
Old 17-08-2005, 06:49 AM   #1 (permalink)
Default Which DVD wirter to buy?
PLease suggest me a good DVD wirter, my budget is is not more than Rs.4500/-. Tell me a good DVD writer with dual layer. Also tell me what is lightscribe and what is the cost of the DVD-writer with lightscribe.
divyadbzgt1 is offline
Old 17-08-2005, 09:25 AM   #2 (permalink)
MVP in VC++
Hey i have not heard of SE DVD Writers no Alcatel????
Well well u can go for
Sony DVD Writer 16xD 16x, Dual Layer, 8.5GB which costs 4000/-
Samsung DVD Writer 16xD 16x, Dual Layer, 8.5GB which cost 3200/-
LG DVD-Writer 16xD 16x, Dual Layer, 8.5GB which costs 3400/-
cvvikram is offline
Old 17-08-2005, 12:38 PM   #3 (permalink)
lightscribe has a coating which you can burn off, so you can make cd covers on the cd itself. But it takes as long as it takes to burn the cd so to do a cover adn burn the cd it will take twice as long.
I would try to find a Motorola cause my cable modem is by Motorola and after 5 years and numerous lightning strikes, it still works.
AlienTech is offline
Old 18-08-2005, 07:50 AM   #4 (permalink)
BenQ DW1640. PERIOD
Hmmm...do i need one?
sunmysore is offline
Old 18-08-2005, 08:01 AM   #5 (permalink)
Benq DW 1640 , Dont think abt ne thing else.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
Old 18-08-2005, 08:13 AM   #6 (permalink)
I third that DW1640, without doubt the best DVD writter in the world right now.
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
Old 19-08-2005, 12:05 AM   #7 (permalink)
benq 1640 best buy at present........hav good reviews on cdfreak site...........also will cost only ard 3.6k depends when it hit market..in south it has gone as low as 3.3k......in mumbai cam b4yesterday..3.55k here presently
magnet is offline
Old 19-08-2005, 06:05 AM   #8 (permalink)
IS Benq 1640 available in chennai market
Old 19-08-2005, 06:07 AM   #9 (permalink)
Yep. Couple of my friend have even bough it in chennai and areas around chennai.
If you wana know from where to get it from chennai and you cannot find it with your dealer PM me. I will introduce you with my friends there and you can talk to them and get this drive.
Do not settle for any other drive at the moment.
Old 19-08-2005, 11:38 AM   #10 (permalink)
i think, benq dw1640 doesnt have light scribe and wat is the btw ur poll and question??
Shwetanshu Srivastava
shwetanshu is offline
Old 19-08-2005, 11:54 AM   #11 (permalink)
yep DW1640 dosent have lightscribe.
But if you are looking for performace drive with best compatability, speed and ability to burn slower disks at higher speeds, frequent firmware updates then there is no competition ofr DW1640 now.
DW1625 is lightscribe drive from benq.
Old 20-08-2005, 09:53 AM   #12 (permalink)
1640 rules...since the BSKB firmware, the ability to write any DVD at 16X rules!!!!!!
Old 20-08-2005, 05:14 PM   #13 (permalink)
BENQ is the best one for +R disks. Pioneer is the best one for -R disks. I just got a LG4163B since I could not find any of the others. They tried to sell me a Sony which is the same as the liteon which is a pathetic drive. It is such a relief to not spend an hour after each burn trying to make sure the disk is all right. (Scan disk/speed test/kprobe test).
LG is the only drive which writes in CAV mode. IE the speed of the write increases from the slowest to the fastest near the end of the disk. All the others use zones which write at a particular speed in each zone then switch to a higher speed as the written area moves to the end of the disk.
LG is much slower than the others, but reliability has become very important to me after using the liteon. Better to spend an extra minute on burning a disk and be sure it was done right than saving a minute in burn speed and spending a few hours making sure the disk works. It takes the LG 8 minutes to write a full disk. Well the Liteon took over 9 minutes so not sure why they say the LG is slower.
http://club.cdfreaks.com/showthread.php?t=122223
Review of the Philips DVDR1640P. Or BENQ.
The drive can write some types of 4x DVD+R media at 8x/12x and 8x media at 12x/16x.
http://www.cdfreaks.com/article/152
Ps.. Seems the BENQ is now also using CAV mode. And barring all the hype NEC/PIONEER/BENQ/LG seems to all be reliable and fast drives with each having some strengths due to which media they developed/created. Other than Sony who cant do much even with +R media because they are all playing games at work instead of developing stuff.
And tests show that the Benq1640 writes better because well, its slower than the Benq1620. And more media can be burnt higher than rated speeds. But then again I could burn my phillips 2X +R media @ 8X on my liteon. Which dont say much for the drive over all.
Old 20-08-2005, 09:52 PM   #14 (permalink)
i can burn 4X -R at 16X on mine.......
Old 21-08-2005, 02:44 AM   #15 (permalink)
yogi7272's Avatar
hi people, just got my benq 1640 yesterday .. fantastic drive .. especially with new firmware ... got to say this is the best dvd writer now ..
can burn any media at 16x with good quality ..
so go for it
yogi7272 is offline
Old 21-08-2005, 03:39 AM   #16 (permalink)
How long does it take to burn a disk? I am happy with 8 minutes as long as it is reliable. If the speed was like 7 minutes with verify then I would look at something else like writing it @ 32X. IE the faster you write the less reliable it is. For many things people still have to write slower than necessary, like recording Audio CD's. I haven't noticed a difference in writing it at 24x.. But some can tell the difference. Sony play station games need to be written slower. So do sega dream cast. But I save time by creating coasters.. IE I burn the CD @ 40X+, see if it boots since it takes a minute to test it, Sometimes it only locks up in the middle but that is rare, if it dont I burn it again @ 12X which always works. Some times I can burn it again @ 40X+ and see if it works, maybe the 3rd or 4th time will work... But with slower burning it always works. Saving 4 minutes to save a coaster...
Speed ain't all it cracked up to be. What ever works.. IE do the best job that takes the least amount of time. Not do the job as fast as you can.
Americans have figured this out and became #1 but lately they been thinking #1 means emulating Microsoft. Which is more like brute forcing others to say you are #1. You can look at US quality of products compared to EU quality. I used to reprogram EU products for US markets, we used to spend longer than it originally took to do the program just to fix the bugs, fix user interface problems and other things. Forget Indian or Chinese quality. And Japanese quality is always more expensive than anyone else. IE their stuff costs so much more than anything that no one wants it, but they subsidize it so it sells cheaper outside japan while costing twice as much at home. Unlike India where they sell good quality stuff outside India for half the price while selling bad quality inside at twice the price. Moser baer is a grand example of this I noticed the past year trying to get good quality DVD's.
Old 21-08-2005, 08:49 AM   #17 (permalink)
yogi7272's Avatar
hey alientech , u seem to have very good knowledge abt the odd stuff ..
i have tried all the available media on benq 1640 .. it can write 16x to all of them .. infact i have written all the media at 16x.
time taken is between 6 minutes to 9 minuted depending upon the media.
surprise is that the fastest time i have got is with this media named 'unique' -rated speed 8x -- 6 minutes flat for 4.3 gb data- nero cd-dvd quality score of 93 .. not bad i should say ..
last thing .. maybe ur spot on abt the moser baer media .. cos the media id of moser baer and unique is the same!
benq dw 1640 is the best....
yogi7272 is offline
Old 21-08-2005, 11:17 AM   #18 (permalink)
get some Mitsubishi or Maxell 8X DVD+R and burn them at 12X will give wonderful quality as well as speed
Old 21-08-2005, 02:41 PM   #19 (permalink)
yogi7272's Avatar
hi sunmysore , thanks for ur advice buddy , i have got a question ..
i have been visiting www.cdfreaks.com
in their forum go to benq/philips dvd writer section ..
there is a topic named media code speed edit at the top ..
now i have seen many guys their who have patched their bskb firmware with mcse ...
i have tried too ... but without any success .. now have you or anybody else got a idea abt this ... they say that after the patching the read speed for dvd rom DL media is increased to 16x...
now is that so neccessary?... i am a bit confused as how to patch the firmware ? anybody pls help ........
yogi7272 is offline
Old 21-08-2005, 08:11 PM   #20 (permalink)
You can write any disk @ 16x by changing the mediacodes even on the LG. But only for media that can handle it.
http://club.cdfreaks.com/showthread.php?t=133858
MediaCodeSpeedEdit tool for DVD-Writers
http://club.cdfreaks.com/showthread.php?t=114269
Latest Version:
http://ala42.cdfreaks.com/MCSE/MediaCodeSpeedEdit.zip
Old 21-08-2005, 08:47 PM   #21 (permalink)
MCSE voids ur warranty...and ther is a gr8 risk not flashing the way the manuf wants u to
Old 22-08-2005, 05:58 AM   #22 (permalink)
Manufacturers say lots of things, the only good thing about it is, If something goes wrong you can take it back and get another one. It does not mean what they say is right. Because if you followed manufacturers sayings, most of this forum would be empty since it seems to always be about over clocking something. Manufacturers have now gone far enough to put in hardware blocks to prevent so many people from doing things they do not like. In fact AMD has now gone from just using resistors to set clock multipliers to now using a heat shield that can not be removed to prevent people from unsoldering the resistors to set their own speed locks.
2 of the cheap media I found here was the Edge tech 8X media code FUJIFILM03 and the NexGen 8X media code MCC 02RG20. I am not sure if these are manufactured by Moser Baer or not. They could be Moser OEM's.
If I can get PIF values of 23.. Errr even under 5000 or so then well hell I will spend 10 minutes on a disk instead of the 8 minutes @ 8X. Over speeding gets you done in 6 minutes but I am sure the PIF numbers will shoot sky high errr at least in the 500 range... The lite on was giving me in the 1000's range even burning this @ 2X.
Write Time: 5m:20s using MCC 03RG20 but not sure where to find those disks yet... maybe in another few months they will replace the 02RG20's. PIF's less than 100 is extremely good. Unbelivable in fact. Even with RW media I have not seen such low numbers.
Old 22-08-2005, 06:14 AM   #23 (permalink)
DW1640 - BSKB Horrible Quality for RW-Media
Well just dont use RW media with it just yet. Considering 4X/8X RW media costs 200 on up.... Older firmware seems to work okay. I use RW media to backup the system since it is done so often.
http://club.cdfreaks.com/showthread.php?t=146608
Old 06-09-2005, 10:16 PM   #24 (permalink)
any one knows
benq dealers in delhi / ghaziabad??
hsnayvid is offline
- by Krow
