Can u give more details pls about professional quality capturing card?
Search for Pinnacle products. They offer good quality capturing cards. They range from 8000 to 14000 normally.
As u told in second method, its attached with TV, it means we don't need a comp for it, right?
And what after we hv captured the clip from TV into this card?
How we retrieve it and save it on comp?
How much space available in it, I mean how much long a clip can be captured into it?
How much it costs?
Wrong. you still need a computer. The capturing card should be installed in your computer. (It may be either internal or external). And in that capturing card you have options for AV connections.As like normal VCR connection, you can connect ur TV to the capturing card, and then can capture high quality (they support DVD quality capturing) video.
A high quality capturing cards are normally available at a price range of 10000- 16000Rs. There are also some good capturing cards available for a price of 8000 or less.
Visit
http://www.pinnaclesys.com
