Hi! I m running Win XP Pro, Zone Alarm and Mcafee enterprise edition. Whenever I connect to internet my virus scanner detects a virus type bo:stack . Plz. help me i did a google seacrh and foud nothing.
Thx!
That's McAfee buffer overflow protection kicking in. You need to update to sp2 and install all updates from Windows.
Keith
SP2 contains a lot of critical updates for systems especially those that connect to the internet. Infact a lot of the security firms advise the people to install Sp2 as soon as possible. Installing Sp2 and combining it with your AV and your anti-spyware tool should keep your system secure.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
AMD 64 3500+ Venice
