In the Windows Task Manager in XP under the Process tab there is a list of all the processes currently exucuting on the system. But there are 4 processes of name SVCHOST.EXE. I want to know what this process does and why are there are 4 process with the same name. I would also like to know which processes are important for XP to work and what do these process do.
well i too got 4 of them . and i think as already mentioned that these are all windows essential.
but got to add also-
i think u did c it as svcost.exe but just in case u got it wrong(very unlikely)
svghost.exe is a virus or malware.
"Try again, fail again, fail better" - Samuel Beckett
removing the remote procedure call or remote registry might create some problems .though this is a big vulnerability; but when i disabled it my restart took ages.
