Old 21-09-2004, 08:05 AM   #1 (permalink)
Default 2 IP Addresses or Loopback Interfaces on 1 computer ??
Hey .. I wanna test my networking applications on my standalone computer ... but for dat i require 2 IP addresses ... 1 is the MS Loopback interface ... but can ne1 temme where do i get the 2nd IP from .. ges there may b a way 2 emulate another loopback interface with another IP address!!
If ne1 knows bout an emulator for this or simply a workaround 2 get 2 IP addresses on 1 computer ... plzz hlp
nikhilwason is offline
Old 21-09-2004, 02:34 PM   #2 (permalink)
put in a network card (RS 250 in bangalore) and you can assign multiple ip to it using alias.
**** happens
pradeep_chauhan is offline
Old 21-09-2004, 10:55 PM   #3 (permalink)
Version 2.0
Deep's Avatar
using different protocol ? i.e PPPOE or something ?
i use it that way only
or may be you can use VM ware and setup virtual system and check the stuff..
but i will suggest buying NIC and test it
check this out : http://www.google.com/search?q=multi...on+one+machine
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
- by Krow
