Old 15-08-2005, 01:43 PM   #1 (permalink)
adit_sen's Avatar
Default this is driving me nuts!!
hey guys...pls pls help me out on this one.
i use opera to surf the net. now from time to time when im online, the computer just stops responding. no windows open or close. but the funny thing is that the mouse cursor moves...any open windows can be minimised (but not opened again once minimised)...and if i have some music or sumthing running on winamp playing, it keeps playing with no probs...that doesnt hang!! but i cant operate winamp in this situation..!! pls pls help. i thought it was an opera prob, but same happens wit other browsers too while connected to the net. i have scanned for spyware using ms antispyware and viruses with avast but found nothing. if i restart the computer, winxp boots up fine wit no prob, and does not even do a disk check. it just loads back as if nuthin happens...so PLS HELP!!!
peace..
adit_sen is offline
Old 15-08-2005, 01:50 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
what is SP version?? i mean do u have the SP2 install??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-08-2005, 01:54 PM   #3 (permalink)
adit_sen's Avatar
yup...i have winxp wit sp2...
adit_sen is offline
Old 15-08-2005, 05:23 PM   #4 (permalink)
expertno.1's Avatar
might be some attack from net
get your firewall with tight position
expertno.1 is offline
Old 15-08-2005, 05:32 PM   #5 (permalink)
Rebooting
u can go through this 2 articals...
Some programs seem to stop working after you install Windows XP Service Pack 2
Windows XP Service Pack 2 Problem Solver
& also when the problems occurs... use the Task Manager to shutdown the Not responding Programs...
rebooting
ChotoCheeta.com
Old 17-08-2005, 01:54 PM   #6 (permalink)
adit_sen's Avatar
i read the articles u mentioned but they are related to solving problems after sp2. i dont seem to have any sort of trouble mentioned in the articles. my problem is
->the computer 'hangs' when connected to the net, but the mouse cursor works. the alt-tab function works, but does not switch the programs. no new program can be opened, but existing programs can be closed.
->all existing windows can be can be minimised, but not restored.
->taskmanager cant be opened in this situation
->if windows is forcefully shutdown, when it starts again scandisk does not run.
SO PLS PLS HELP ME OUT...
thankx
adit_sen is offline
Old 17-08-2005, 02:18 PM   #7 (permalink)
does this happen only when ur connected to the net ? which AV solution, if any, do you use ? If it is a problem only after internet connection defenitely sounds like a virus/trojan to me. Install Kaspersky and do a complete system scan and eliminate all virus instances you find.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 17-08-2005, 02:26 PM   #8 (permalink)
adit_sen's Avatar
yup...this happens only when i connect to the net. i use avast pro version 4.6.691. it doesnt detect any viruses..and my virus definition files get updated daily..
adit_sen is offline
Old 17-08-2005, 05:54 PM   #9 (permalink)
royal's Avatar
Mebbe u cud use Spyware removal tools like
SpyBot,
Ad Aware,
Xoft Spy
royal is offline
Old 18-08-2005, 07:44 AM   #10 (permalink)
Let the music play.....
djmykey's Avatar
Ok tell me what pc u use coz I use a p3 700 MHz and 128 MB SDRAM and this hanging happens only when I open too many windows with high res images check if it happens with you also.
djmykey is offline
- by Krow
