Old 15-08-2005, 11:07 AM   #1 (permalink)
The CREATURE
zodiac_511's Avatar
Default Sound Problem
Ultimately I bought my new system.
It has a MSI K89 Diamond Mobo with a Sound Blaster 24 bit Live! (onboard) and Creative Inspire 4400 4.1 Channel speakers .I have installed games like Doom 3 ,Nolf 2 ,GTA SA ,etc etc etc... .The problem is that when playing GTA SA I don't hear the sound of the cars' engine (ie the car CJ uses) and in NOLF 2 i dont hear the weapon sounds (ie reloading and firing) but all the other sounds play fine. But when i disable ll the other sounds (ie background sounds,etc ) and increase the speaker volume to full blast ( I bet u know how these speakers sound @ those levels ) I can hear of only faint sounds of the car in San Andreas and gunfire in NOLF 2 (No one lives forever 2) . Please Help . Also music plays only thru the front speakers while games with EAX utilise all the 4 speakers (GTA SA ,NOLF2 AND DOOM 3) is this normal ?
PS The Doom 3 sounds work fine and the game rox . I'm in the caverns now.
I can reply only after a fortnight as i'm a hosteler (SRV Schools near Salem) 8)
..::: ||ZoDiAc|| ::..
zodiac_511 is offline
Old 15-08-2005, 11:48 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Make sure tht ur SKP system is Plugin properly....
Go to Control Panel, Click Sound & Audio Devices
now Select Sound & Audio Devices
Click Advence
Now Config ur Spk system to play 5.1 or 7.1 Sound...
Then Reboot....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-08-2005, 11:56 AM   #3 (permalink)
The CREATURE
zodiac_511's Avatar
I've tried tht already but my speakers are 4.1 i have them set @ surround speakers now . But I'll try ur suggestion
Old 15-08-2005, 10:26 PM   #4 (permalink)
q3_abhi's Avatar
Which OS??? Tried on other OS??????
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 15-08-2005, 11:49 PM   #5 (permalink)
siriusb's Avatar
Your sound card must've come with a test utility. Test to see if each of ur speakers are ok sounding.
It might also help to check the games' compatiblity list for your sound card.
Perhaps you may need to toggle eax and/or harware sound.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 16-08-2005, 09:00 AM   #6 (permalink)
MVP in VC++
Yup try with the Sound Testing software provided along with the sound card or provided with mobo.
cvvikram is offline
Old 27-08-2005, 05:43 PM   #7 (permalink)
The CREATURE
zodiac_511's Avatar
Saurav's Method didnt work
@ abhi i use xp (sp2)
@siriusb i'll try ur suggestion
Old 27-08-2005, 08:48 PM   #8 (permalink)
expertno.1's Avatar
how to do that ?
expertno.1 is offline
Old 27-08-2005, 09:00 PM   #9 (permalink)
siriusb's Avatar
I was referring to the in-game audio option which toggles hardware/eax sound.
siriusb is offline
Old 27-08-2005, 11:14 PM   #10 (permalink)
 Macboy
goobimama's Avatar
In case you didn't know, the 4400s are not surround speakers but quadraphonic speakers. There might lie your problem...
I'm like a bird... :)
goobimama is offline
Old 28-08-2005, 08:59 AM   #11 (permalink)
The CREATURE
zodiac_511's Avatar
@goobimama
the speakers worked fine with doom3 when set as surround speakers
Old 28-08-2005, 10:05 PM   #12 (permalink)
GTA SA version has several bugs related to audio.
Go to the company website to download fixes.
hsksattish is offline
- by Krow
