Old 14-08-2005, 11:31 PM   #1 (permalink)
Thor's Avatar
Default Determine if a credit card number is valid using VB6
Takeaway:
If you support a Web site that accepts online payments, the first step in any process that accepts credit card numbers should be verifying the number. This tip shows how to do this using VB6.
Credit card numbers are not assigned at random. Each number, usually 16 digits long, must adhere to certain mathematical conditions to be valid. This is called the Luhn Check, and it is used by almost all major cards. If you support a Web site that accepts online payments, the first step in any process that accepts credit card numbers should be verifying the number. This tip shows how you can do this using VB6.
Using VB6, the credit card number is passed, as a string, to the function CCNumberValid. The string must contain only digits—no embedded spaces or dashes. The function returns True if the number is valid and False if not.
Public Function CCNumberValid(ByValCCNumber As String) As Boolean
Dim Result As Long
Dim Total As Long
Dim idx As Integer
Dim i As Integer
Dim j As Integer
j = 1
For i = Len(CCNumber) To 1 Step -1
Result = (CInt(Mid$(CCNumber, i, 1)) * j)
If Result >= 10 Then
Total = Total + (CInt(Mid$(CStr(Result), 1, 1)) _
+ CInt(Mid$(CStr(Result), 2, 1)))
Else
Total = Total + Result
End If
If j = 2 Then j = 1 Else j = 2
Next
If Total Mod 10 = 0 Then
CCNumberValid = True
Else
CCNumberValid = False
End If
End Function
The fact that a credit card number is valid does not mean that it is actually assigned to an account or that the account is in good standing. But checking the validity of a number is the best and fastest way to weed out errors in number entry.
Courtesy : Techrepublic Newsletter.
Or See Link at : www.snipurl.com/ccheck
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 15-08-2005, 01:03 AM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Script shows error at Line 1 Char 45.
navjotjsingh is offline
Old 15-08-2005, 01:18 AM   #3 (permalink)
@Thor: I too got the same error Line 1 char 45
Plz post the link from TechRepublic so we can try using tat.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 15-08-2005, 01:30 AM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
same problem here. gimme link to source.
n00b forever...
~Phenom~ is offline
Old 15-08-2005, 11:46 AM   #5 (permalink)
Thor's Avatar
Ok. Link Posted with Original Post. Sorry 4 thy Inconvenience.
Thor is offline
Old 15-08-2005, 06:49 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Thnx a lot, now i know how to evade CC checks...
Harsh J
www.harshj.com
QwertyManiac is offline
- by Krow
