HP 1022 is a nice laser printer within 15000 range----- its prints upto 18ppm, speed 266MHZ, 8MB RAM, 1200dpi resolution - it is 11750 +vat
HP 1020 is 8950 +vat,
it has 14ppm, 234 MHz, 2 MB RAM, 1200 dpi resolution..
print quality of botha re same one is more costly because it prints fast and has more RAM... if ur budget is 15,000 then go for 1022 else 1020 is not a bad printer..
and the last it is HP laserjet 3015 -- that might cost around 15,000+ or may be less. it has printer, scanner copier as well as fax..
it print upto 15ppm,
33.6 kbps, 110 page memory fax,
copy and fax without PC,
30 Sheet ADF,
32 MBRAM ---> thats great
240 MHz speed
if u want just a laser printer then go for 1022 laserjet.
the prices are calcutta based since jul22nd till today.
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
