Old 14-08-2005, 04:52 PM   #1 (permalink)
sujeet2555's Avatar
Default agp slot
can anyone tell me if there any motherboard that can support both agp and pci-express graphic card.are intel 915 motherboards backward compatible i-e for older ddr ram,pata hd ?and one more thing. which is better intel graphic media accelerator or my old nvdia mx 4000?
s.k.
sujeet2555 is offline
Old 14-08-2005, 05:38 PM   #2 (permalink)
why do u need both yaar.
pcie outperforms agp n all graphic cards companies rinclinign towards itself.
915g series is backward compatible as u said.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 14-08-2005, 06:19 PM   #3 (permalink)
sujeet2555's Avatar
Default Re: agp slot
i am willing to buy a pcx graphic card later on and wishing to use my old card instead.you didn't tell me which is better intel graphic media accelerator or my old nvdia mx 4000?
s.k.
Old 14-08-2005, 06:57 PM   #4 (permalink)
siriusb's Avatar
There are mobos with agp slot on a pciex architecture, but they use pci bus to emulate agp and hence they have a bit slower interface to the vid card. I read of such mobos in tomshardware but I haven't seen one.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 14-08-2005, 10:10 PM   #5 (permalink)
q3_abhi's Avatar
Ya,this is a transition period n i think that definitely, there may be some motherboards of this type.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
- by Krow
