ok. then you must haf a config utility as a program group if not in control panel.
since i hafnt used pc suite (i own a SE phone), i dunno wot are the connectivity options in it. afa my case is concerned, i use float's media agent (FMA) and i've configured my bluetooth as follows:
uninstalled the bluesoleil drivers, installed widcomm ones. enabled the virtual com port via config utility and selected the connection as serial port in FMA. essentially its just an emulation. the software thinks that its a serial communication but in reality there are no cords and the comm is by bluetooth by a com port emulation.
ok, i dun haf specific nokia + bluesoleil config, but the lnk given below explains the connection of a SE phone using widcomm drivers. you should be able to figure out the analogous parts in nokia suite + bluesoleil.
http://www.mobileagent.info/forums/i...wtopic=32&st=0
