Old 14-08-2005, 01:20 PM   #1 (permalink)
Default How to convert DVD Movies TO VCD
Hello,
I have a DVD with 5 movies on it. I can play the movies on my pc cause I have dvd writer but not on the tv as I only have a vcd player. I wanted to copy the movies on to cds without much loss of quality. For this, I think I will have to split each movie & write onto 2-3 cds. But I don't know how to split each movie into 2-3 dat files.
Please help me. I hope my problem is clear.
Thank you & have a nice day.
siddhesh is offline
Old 14-08-2005, 01:26 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Search.
http://www.thinkdigit.com/forum/viewtopic.php?t=20181
Creating VCD's with subs:
After installing ffdshow, add the path to the subs file in ffdshow configuration menu. Once the path is added, TMPGEnc will automatically display the subs that's already loadeded in ffdshow. Some ppl use TMPGEnc to convert avi files to vcd compatible format. Also in TMPGEnc environmental settings, priority for direct show should be increased to 2.
THen i guess, u can write in the DVD , but it will come up as a VCD format only but u will get great quality as the previous .avi file u had.
Hope this is the thing that you wanted to know..
drgrudge is offline
Old 19-08-2005, 01:46 AM   #3 (permalink)
Thankx drgrudge!
I found a better software to do what I wanted to. It is Ahead DVD Ripper
Thankx anywayz. Have a nice day!
siddhesh is offline
Old 19-08-2005, 08:12 AM   #4 (permalink)
expertno.1's Avatar
Ahead dvd ripper rocks !!!!
expertno.1 is offline
Old 19-08-2005, 09:17 AM   #5 (permalink)
MVP in VC++
Yup u can go ahead with Ahead dvd ripper it really cool
cvvikram is offline
Old 19-08-2005, 11:26 AM   #6 (permalink)
ya i started using just now and i like it for its simple interface and ease of use
Shwetanshu Srivastava
shwetanshu is offline
Old 19-08-2005, 12:40 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yeah ! tis easy to use and good quality too,
P.s.? does Nvidia pure view workwith Intervideo 7 windvd, coz for me it doesnt play anything....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-08-2005, 09:01 AM   #8 (permalink)
q3_abhi's Avatar
Ahead DVD ripper comes with Nero Burning ROM cd???
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
- by Krow
