Old 20-09-2004, 10:07 PM   #1 (permalink)
fanatic's Avatar
Default ISP always connected
I have Windows XP, Raspppoe Over Ethernet Cable internet.
Suppose this is my ipaddress of my isp : 192.168.1.11
Now this dude is always connected to my computer
Whereas on my friend's pc, this isnt the case.
Heres how i found it out:
When i enter NETSTAT command this is what it shows
Proto Local Address Foreign Address State
TCP Mypcname:epmap 192.168.1.1 : 2271 Established
And there are other TCP entries which are of msn and stuff
But this isp i dont know what the hell he wants from my pc.
Can anybody explain me, how to just disconnect him, or trace him
as to what hes doing to my PC.
http://xforum.hugetop.com
Tutorials, Whitepapers, Beginner articles, How tos and Getting started Tutorials. All information you need about Computers, Ethical Hacking, Security, Web, Web Programming.
fanatic is offline
Old 20-09-2004, 10:55 PM   #2 (permalink)
mariner's Avatar
as u know his ip u can trace his ip from www.whois.net or from
whoisarin.net. also if u use a firewall u can get the logs from ur firewall.
email all this to his isp as they have an abuse department.
also u can send this info to support@thehackersisp.com.
thouroughly scan ur pc as u may have a trojan or a rat installed.
also see that u dont have any folder like printers etc shared.
try to get blackice defender firewall.
presently i m using sygate and soon shifting to blackice.
above information taken from " hacking secrets revealed "
a production of s & c enterprises.
mariner is offline
Old 20-09-2004, 10:58 PM   #3 (permalink)
hi buddy you are having same connection as i m havind.
This 192.168.1.1 is the address of the main server from which you re accessing the net. This means that you are on LAN and you are using net from this computer.
I have many hacks for this type oof connection That is how to make it work in day if you are having a night connnection.If you want them then contact me via PM.
good luck.
killerguy is offline
Old 20-09-2004, 11:48 PM   #4 (permalink)
fanatic's Avatar
Default i dont wanna install firewall
my net slows down when i install firewall
and i cant watch cams when i install firewall
any other option other than firewall one
fanatic is offline
Old 21-09-2004, 09:27 AM   #5 (permalink)
fanatic, I think 192.168.1.1 is your gateway server, you have to remain connected to it in order to access the internet. If you block it then you would be disconnected the internet.
wORm is offline
Old 21-09-2004, 01:03 PM   #6 (permalink)
mariner's Avatar
well fanatic u can watch cams even after u have installed a firewall. where did u get this idea from that u cannot watch cams with a firewall?
a firewall is a must today if u want to be safe !!
mariner is offline
Old 21-09-2004, 10:04 PM   #7 (permalink)
fanatic's Avatar
Default ok dude
ok dude, i ll install a firewall
yep that problem goes away when i install a firewall
thanks buddy, i thought with firewall the net would go slowdown and stuff
fanatic is offline
- by Krow
