Old 14-08-2005, 11:19 AM   #1 (permalink)
pradipudhaya's Avatar
Default Yahoo Messenger 7.0.0.426 Help
Hello, I recently installed version 7.0.0.426 of yahoo messenger. I use Norton Personal Firewall 2005. I am able to logon yahoo messenger in safe mode of windows (when the firewall is inactive), but not in the normal mode. How should I configure my firewall? Thank you.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination - if you don't, I'll set Bunny onto you!
pradipudhaya is offline
Old 14-08-2005, 11:43 AM   #2 (permalink)
well try this.
go to messenger>preferences>connection and select FIREWALL with NO PROXIES. And get going.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 14-08-2005, 11:52 AM   #3 (permalink)
I tried it earlier, no use Earlier I used to use version 7.0.0.242 and it worked fine. I had selected the no proxies then.. I reckon the firewall should be configured. I am not sure of the inbound and outbound ports which needs to be allowed..
(\__/)
Old 14-08-2005, 12:14 PM   #4 (permalink)
Before checking for blocked ports I would suggest first check whether the program[yahoo here] itself has been assigned to be blocked in the Norton Program Control or something similar.
Just search under block programs & change it if it has been indeed blocked.
www.Oobertech.net
digen is offline
Old 14-08-2005, 12:22 PM   #5 (permalink)
It is configured to allow all connections
(\__/)
Old 14-08-2005, 12:59 PM   #6 (permalink)
hmm.. I found a way.. Don't know whether it will work the next time i restart. I rebooted my system.. Disabled NPF and logged on yahoo.. Then I enabled the firewall It asked me whether to permit yahoo, I clicked permit all.. Thanks guys
(\__/)
- by Krow
