Old 14-08-2005, 02:35 AM   #1 (permalink)
Default Compressing files
I have some of files which are of around 35 MB in size but when they are unpacked , they contain around 70-75 MB. which software do i have to use to obtain such type of compression.
mako_123 is offline
Old 14-08-2005, 03:16 AM   #2 (permalink)
hafees's Avatar
You can use Winzip (www.winzip.com)
PowerArchiver(www.powerarchiver.com)
WinRAR(www.winRAR.com)
ZipGenius etc (http://www.zipgenius.it/index2.html) (FREE)
Zip archives are faster than RAR but RAR is better in compression.
hafees is offline
Old 14-08-2005, 03:35 AM   #3 (permalink)
desertwind's Avatar
The amount of compression achived largely depends on the data you are compressing. If its already in a compressed format, like jpg or mpg, you wont get such a compression
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 14-08-2005, 08:16 AM   #4 (permalink)
q3_abhi's Avatar
Try using WinRAR's Best Compression.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 14-08-2005, 01:36 PM   #5 (permalink)
i tried compressing a file of 11.4 MB in size with the winrar best compression but after compression the size was 11.1 MB . How to get compression more than that
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 14-08-2005, 04:01 PM   #6 (permalink)
hack expert's Avatar
well winrar is one of the best but the compression depends upon the type of file ur compressing usually text related files like dll`s and stuff give more compression level so if u compress games and stuff u`ll get better results for setups and stuff it`s low
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 14-08-2005, 10:13 PM   #7 (permalink)
q3_abhi's Avatar
DesertWind has already said that compression depends on the type of data.That data must already be compressed.
q3_abhi is offline
Old 14-08-2005, 10:22 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
@mako_123
mate just what type of file u tryed to compress?? see if u want to compress a NAV05 (Trial) installletion file which is around 35MB... now here no matter what u try u cant make it under 34MB.... why not as its already been compressed...
so if u try 35MBs of .doc, .pdf.... then u can see the work.. it will come down a lot....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-08-2005, 01:32 AM   #9 (permalink)
Hanging, since 2004..
tarey_g's Avatar
compression depends on the type of the file , not all types of file compress to same levels .
btw anyone heard of 'uharc' compression , very high compression but toooo slow.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 15-08-2005, 08:14 AM   #10 (permalink)
q3_abhi's Avatar
UHARC Compressor - i have it, but don no how to use. Can any one tell me how to use it???
q3_abhi is offline
- by Krow
