Old 13-08-2005, 10:07 PM   #1 (permalink)
Default HOW TO WRITE A CD
Hi guys can u tell me how to write a game cd using nero in detail step by step?
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 13-08-2005, 10:33 PM   #2 (permalink)
Go to nero & select data disc
then add ur game setup into files to be written
Then go to write option & select burn cd.
Techmastro is offline
Old 13-08-2005, 10:34 PM   #3 (permalink)
vignesh's Avatar
Do you want to make a copy of a game cd or what.
vignesh is offline
Old 13-08-2005, 11:11 PM   #4 (permalink)
as you have told that you want to make a cofy of game cd.... if that is so then simply use the copy cd wizard in nero to wirite a cd... and if you are trying to do something else then please tell in details....
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
Old 14-08-2005, 01:09 AM   #5 (permalink)
bharat_r's Avatar
May be he has a copy protected game which uses protection like Safedisk ,etc
Then u need apps like Alcohol 120% or Clone CD.
But these are used to create back ups of the 'original' CDs u have.
bharat_r is offline
Old 14-08-2005, 01:44 AM   #6 (permalink)
well if the game is protected then alcohol 120% is the option to use... as it copies all protected cd and also makes the CDs we write protected(if we wish to)
The Knight Rider
Old 14-08-2005, 08:26 AM   #7 (permalink)
q3_abhi's Avatar
1.Start Nero:
2.Click on "Copy Disc".
3.Select the destination n Source drive.
4.Select the speed. (52x,40x,32x....)
5.Click on burn.
6.After "Burned successfully" click on next.
7.Tray along with the CD will be ejected.
8. Ur game CD is copied.!!!
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 14-08-2005, 10:39 AM   #8 (permalink)
vignesh's Avatar
Its legal if its for yourself..
vignesh is offline
Old 14-08-2005, 11:47 AM   #9 (permalink)
CloneCD is a famous one. But as mandar asked he needs to copy a cd, i dont think prob is so complicated. right?
Instead i have an advice. Try out things in a more diverse manner. This will help u in long run. Happy Computing.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 14-08-2005, 02:07 PM   #10 (permalink)
hey guys tell me in detail which cd should i insert first and when to insert blank cd? I want to give copy of midtown madness 2 cd we got with digit june issue
mandar5 is offline
Old 14-08-2005, 10:18 PM   #11 (permalink)
q3_abhi's Avatar
Source Drive= where u insert the CD to be copied.
Destination Drive = ur writer.
It seems that u have one drive. So Source n Destination is the same drive.
First insert the CD to be copied n then ur blank CD.
N copying the Midtown Madness CD is illegal.
q3_abhi is offline
Old 15-08-2005, 04:25 AM   #12 (permalink)
ok. if u want to write the game as data to the cd, the open nero burning rom or if it is nero epress then change it to nero burning rom as it is easy to use. then file - new - the select data option from left box.
then pick up the datas from ur right side explorer window to the left side explorer window
then open file - write these files to cd or write cd
then set the write speed at the right top end tab bar.
then click burn
and view the cd getting burning
mad_crazyboys is offline
Old 15-08-2005, 06:42 AM   #13 (permalink)
expertno.1's Avatar
the best would be to use clone cd or virtual cd 7
expertno.1 is offline
Old 15-08-2005, 08:54 AM   #14 (permalink)
vignesh's Avatar
Try alcohol 120%.It was given in Aug 2003 mindware.
vignesh is offline
Old 15-08-2005, 09:31 PM   #15 (permalink)
Commander in Chief
QwertyManiac's Avatar
but isnt alcohol 120% blacklisted in some games ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-08-2005, 11:03 AM   #16 (permalink)
royal's Avatar
For making an EXACT cd copy Clone CD is THE best ...
it has even got an option for copying game cds ... 8)
also u can try to use Clony XXL with it
royal is offline
Old 17-08-2005, 12:19 PM   #17 (permalink)
KoRn's Avatar
HEy guys where can i get alcohol 120% i dont have previous digit cd's.cuz in chip mag it came wit a price!!!
<<<*Liv3 F@sT Di3 FuN*>>>
<<H3@dB@nging My W@Y ThRoUGh LiF3>>
KoRn is offline
Old 17-08-2005, 05:01 PM   #18 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
www.alcohol-soft.com
navjotjsingh is offline
Old 17-08-2005, 07:50 PM   #19 (permalink)
KoRn's Avatar
navjot ur supposed to pay in dat site anyway i already got it from ma pal.thanx anyway
KoRn is offline
- by Krow
