Old 13-08-2005, 07:05 PM   #1 (permalink)
Default OEM Version
Can you guyz tell me what is the problem with OEM version of Windows XP Home SP2 if any.
divyadbzgt1 is offline
Old 13-08-2005, 09:33 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
absolutely none, that i know of !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 13-08-2005, 11:01 PM   #3 (permalink)
The problem is that you can only get the OEM version bundled with a new computer! It is not to be sold separately.
Nemesis is offline
Old 13-08-2005, 11:42 PM   #4 (permalink)
aadipa's Avatar
And you cannot install it on your upgraded PC, infact OEM is valid only for the PC it was sold with, you cannot upgrade hardware and keep the OS.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 14-08-2005, 07:50 AM   #5 (permalink)
Well i am buying with a PC but will there be any problem after i install it. L
Old 14-08-2005, 11:50 AM   #6 (permalink)
Absolutely no problems.
But consider this -
Unlike retail, OEM's don't come with colourful boxes and detailed manuals and CD's. And like aadipa said, the license is non transferable. It's tied to the hardware it came with. I think Windows activation deletes all records after 120 days. So if you do a major hardware upgrade, you should be fine reactivating as long as the previous activation was done before 120 days.
More info here - http://www.microsoft.com/licensing/default.mspx
Keith
Keith Sebastian is offline
Old 21-08-2005, 02:00 AM   #7 (permalink)
The Hardware Labs
mohit's Avatar
hey i am using an OEM version of Win XP home SP2 ... i bought it separately and i am using an assembled pc .. before purchasing it i had talked with the microsoft connect people and they had assured me that OEM version can also be used if u upgrade ur hardware (without any time limit) ...they just told me i will be able to use it only on one pc at a time... is that true or not ? if i upgrade my comp will i be stuck without being able to activate it ?
mohit is offline
Old 21-08-2005, 11:22 PM   #8 (permalink)
just a small thing to add. OEM CDs unlike the retail ones, can be used only on that machine. I mean, U can Dell CD's only on a Dell Machine.
@Mohit: U got a rite information. Even u upgrade the hardware, u will be able to activate ur copy of windows.
Raj® Anyone else is not me...!!!
rajas is offline
Old 26-08-2005, 10:48 PM   #9 (permalink)
Default see
I prefer Rentail pack than OEM pack.
rajas700 is offline
Old 27-08-2005, 05:34 AM   #10 (permalink)
Default Re: see
What is the cost of Retail?
Old 27-08-2005, 10:47 AM   #11 (permalink)
t3h g04t
teknoPhobia's Avatar
5 thou something for prof and almost 4k for home I dunno x64 edition
technologically challenged.
teknoPhobia is offline
Old 27-08-2005, 12:39 PM   #12 (permalink)
Default Double
Rentail pack amount to *2 of OEM Pack
rajas700 is offline
- by Krow
