no no no,, this is no power supply problem.... there has been some wrong installation .... this happen with 2000.. even if u install a wrong driver then this happens too.. after the post booting.... keep pressing F8..... you will get a menu and try to enter at start windows with the cfig that worked properly last.. then you might get to start windows 2000. if this fails then u got to reload the OS... as u cant access regitsry in 2000-- unlike 98.. best of luck
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
