Old 12-08-2005, 07:00 PM   #1 (permalink)
godsownman's Avatar
Default Battery Nimh
I have purchased a set of rechargeable batteries. As a rule they say that we must discharge these batteries atleast 3 times for better use .
What is the way to discharge these batteries.
The type of batteries purchased are AA size and NImAh .
Thats all thanks.
godsownman is offline
Old 12-08-2005, 07:35 PM   #2 (permalink)
expertno.1's Avatar
simply use it continuosuly in any device to discharge it
expertno.1 is offline
Old 13-08-2005, 12:11 AM   #3 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Technically, NiMH batteries do not have a "memory effect", but strictly speaking neither do NiCds. However NiMH batteries can experience voltage depletion, also called voltage depression, similar to that of NiCd batteries, but the effect is normally less noticeable. To completely eliminate the possibility of NiMH batteries suffering any voltage depletion effect manufacturers recommend an OCCASIONAL, complete discharge of NiMH batteries followed by a full recharge. NiMH batteries can also be damaged by overcharge and improper storage (see the NiCd section immediately above this one). Most users of NiMH batteries don't have to be concerned with this voltage depletion effect. But if you use a device say a flashlight, radio, or digital camera for only a short time every day and then charge the batteries every night, you will need to let the NiMH (or NiCd) batteries run down occasionally.
Source: http://www.greenbatteries.com/nibafa.html#NiMH%20memory
You can find good info about the batteries you purchased here. As it says above you only need to do an occasional discharge and like expert said you can discharge it by using any device until the battery charge gets depleted.
FilledVoid is offline
Old 13-08-2005, 02:01 AM   #4 (permalink)
desertwind's Avatar
Topic already discussed
http://www.thinkdigit.com/forum/view...862&highlight=
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 13-08-2005, 11:52 AM   #5 (permalink)
godsownman's Avatar
See when I bought the charger I was told that the battery takes 3 hours to charge but now if you say that "good" quality chargers first discharge the battery and then charge them then in that case it should exceed the 3 hours stated.
SO how I am to be sure that the battery will be discharged and then charged and not just topped up.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
Old 13-08-2005, 12:07 PM   #6 (permalink)
Sky
Men are born to succeed, not fail.
Henry David Thoreau
For optimum results , manufacturers advice that u should complete some 2-3 charging ang dischargins cycles. This discharging can be done by just utilising in power hungry eqpts like digital camera or maybe a walkman.
Sky is offline
- by Krow
