Old 12-08-2005, 01:27 PM   #1 (permalink)
Default Multi Messenger Required
hey guys i use yahoo messenger as well as msn messenger and also aim sometimes.... now the problem is tht it becomes tough to handle 3 messsengers... and i have heard tht there r multi messsngers which can have all meeseenger in one... so can u suggest some good ones... plz...
help_me is offline
Old 12-08-2005, 01:44 PM   #2 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Default reply
Use GAIM ..... fast flexible multi messenger !!!!
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 12-08-2005, 01:54 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
You have these options:
Gaim
Miranda
Trillian
e-messenger
I have tried trillian and Gaim and don't like it. Man, i tell u, life is gonna be difficult for u as soon as u start using multi IM clients.
1.Whenever u close ur Gaim window, it logs off and not minimises to system tray.
2. Also u need to keep more windows open to keep it going.
3. Also for trill and miranda (never tried it), we need plugins to keep it going.
By the way i have a slow system and i have no problems with Yahoo (even though, it takes up more memory).
drgrudge is offline
Old 12-08-2005, 02:33 PM   #4 (permalink)
okie after reading the post i think... i may stick to different meesengers... but then can u tell me where can i find msn messenger with browser.. or some substitute for msn messenger.. plz
help_me is offline
Old 12-08-2005, 04:27 PM   #5 (permalink)
try trillian
Amit Kumar is offline
Old 12-08-2005, 04:33 PM   #6 (permalink)
Just Do It
Charley's Avatar
Gaim
Miranda
Trillian
e-messenger
I cannot believe no one has used PALTALK as a multi messenger. It works fine for me.
Charley is offline
Old 17-08-2005, 04:14 PM   #7 (permalink)
Check it here u ll definately find out solution of ur problems....
Edit by Deep: Enough of spam now, its time for a free warning...
www.techarena.in - Lastest reviews for Mobile Softwares, Smartphones and other Windows related Softwares.
www.forums.techarena.in - Technology and Computer Hardware Support Forums of India
TechGuru is offline
Old 17-08-2005, 11:57 PM   #8 (permalink)
hack expert's Avatar
Well trillian sure takes the cake
it`s one of the best
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 18-08-2005, 04:00 PM   #9 (permalink)
Just Do It
Charley's Avatar
Gaim
Its a nasty software. Very difficult to manoeuvre
Charley is offline
Old 20-08-2005, 03:15 AM   #10 (permalink)
busyanuj's Avatar
gaIM is by far the best multi messenger.
alternately, if you need a lite software, you can try Easy Message. It's an ultra-lite software barely 251 KB in size.
busyanuj is offline
Old 20-08-2005, 11:49 AM   #11 (permalink)
e-messnger is web based i guess.
n hey can i logonto web based n software both at a time. i m talkin abt yahoo IM.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 09-09-2005, 12:27 AM   #12 (permalink)
Gaim for linux and trillian for windows
fighting for peace is like ****ing for virginity
cryptid is offline
Old 09-09-2005, 06:54 AM   #13 (permalink)
expertno.1's Avatar
i like IM2 Messenger
get it from here
very cryspy looks and speeds
http://www.im2.com/
expertno.1 is offline
Old 09-09-2005, 07:13 AM   #14 (permalink)
deathvirus_me's Avatar
GAIM ....
U can change this option to "minimize to tray on exit" from the preferences .....
deathvirus_me is offline
Old 09-09-2005, 07:55 AM   #15 (permalink)
I have only used Gaim & Trillian, and both are equally good where trillian has a slightly better look but very poor emotion icons.
@drgrudge u need to turn on the minimise to Sys Tray plugin from the prefrences box
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 09-09-2005, 09:37 AM   #16 (permalink)
Wat multi-messenger incorporates Yahoo, MSN and GoogleTalk .. I am using these three only
Experts Say, Something Went Wrong With the Jet Crash ;)
D1G1TiZed is offline
Old 09-09-2005, 11:40 AM   #17 (permalink)
Just Do It
Charley's Avatar
@D1g - None right now.
Charley is offline
Old 09-09-2005, 11:45 AM   #18 (permalink)
Then i guess i should stick to Y!msnger 7, Msn Msnger 7.5 nd google Talk Beta
Old 12-09-2005, 10:30 PM   #19 (permalink)
I use Trillian pro, and it works fine for me.
I can log in to three of my Yahoo IDs and also log in to msn messenger all at the same time.
It is really fun and the one at the other end will defenitely be confused
Some tweaking makes trillian the best multi messenger.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 13-09-2005, 01:40 PM   #20 (permalink)
www.e-messenger.net
is good...even you dont require to install the software
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
ravimevcha is offline
- by Krow
