12-08-2005, 01:10 PM
FOLDER BACKGROUND IMAGE
How to put a background image for folder like done on win 98 ,here is the link take a look
http://windowsxp.mvps.org/Customize_folder.htm
it was able to modify the background by editing the folder.htt
where to edit to modify the folders in win xp ?
please help me modify
12-08-2005, 10:25 PM
Rebooting
[ edited]
oppss wrong reply....
__________________________________________________ ____
Ok this time more appropiate answer...
To add wallpaper to a folder in XP, open the folder, choose Tools, Folder Options, and click the View tab. Under 'Advanced settings', select Show hidden files and folders (you may need to double-click Hidden files and folders first). Uncheck Hide protected operating system files (Recommended) and click Yes when you see the warning. Click OK, and double-click the file named desktop.ini to open it in your text editor (you may not see the .ini extension). If you can't find a desktop.ini file, launch Notepad or your preferred text editor.
In your text editor, type [{BE098140-A513-11D0-A3A4-00C04FD706EC}] (this line contains no capital letter Os, only zeroes) on the first line, and press Enter. Type IconArea_Image= and the path to your .bmp, .gif, or .jpg image file--for example, 'IconArea_Image=C:\My Documents\My Pictures\Blue Hills.bmp.' Then press Enter.
Changing the color of the folder's icon labels is a little tricky. To leave the icon text black, do nothing. For white, type IconArea_Text=0x00FFFFFF (make sure that the x is lowercase) and press Enter. For red text, replace the code that follows the equal sign with 0x000000FF; to make the text yellow, type 0x0000FFFF; for blue text, use 0x00FF0000; and to show gray text, enter 0x00808080. These codes identify values in a 24-bit color scheme that specifies how much blue, green, and red to mix together: 0x00bbggrr (with values ranging from 0 in decimal or 00 in hexadecimal to 255 in decimal or FF in hexadecimal). If you're editing the folder's existing desktop.ini file, save the file and close your text editor. If you created the file from scratch, save it with the name "desktop.ini" in the folder that will house the background picture; use quotation marks to keep Notepad from adding its default .txt extension.
Now give the folder the System attribute. Put the folder window destined for the background picture in front. Press Backspace to move up a level, click Start, Run, type attrib +s followed by a space, and drag the icon for your desired folder to the text box of the Run dialog box. It should now read something like 'attrib +s C:\Documents and Settings\...\My Documents\My Folder' (your path and folder name may differ, of course). Click OK. The next time you open the folder, you'll see your new wallpaper inside (see FIGURE 3). If you don't want to see the desktop.ini file, right-click it and choose Properties. Under the General tab, check Hidden and click OK. Then click Tools, Folder Options, View, and deselect the option to show hidden files and folders. While the Folder Options box is open, recheck Hide protected operating system files if you unchecked it earlier.
Source...
might wana try their suggetion... hmm...
rebooting
ChotoCheeta.com
12-08-2005, 10:36 PM
hmmm
2 bad xp does not support a background pic for a folder(when opened)like windows 98 does.i loved windows 98.in xp you can customize only the picture of the folder externally
12-08-2005, 10:43 PM
well then Chwamaki!!! why dont u use both xp as well as 98...!!!
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
12-08-2005, 10:48 PM
guys have u not noticed the image appearing when enterng a video fodler or an audio folder or an image folder....there must be some dll which contains the images....
12-08-2005, 10:51 PM
Buying and installing another os is not a reasonable suggestion.
OP:
U can do it in xp. Check here:
http://www.pcworld.com/howto/article...60,pg,2,00.asp
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
12-08-2005, 10:53 PM
Rebooting
well another MS artican has few more tricks...
Customizing Folders with Desktop.ini
hmm...
rebooting
ChotoCheeta.com
13-08-2005, 12:28 AM
Just thought I'd add this....
If you use 98-XP dual boot, any folder background you create in 98 will also show up in XP. This is because the system file created in 98 also works in XP. Too bad XP does not include an easy way to do the same thing.
13-08-2005, 10:57 AM
Thx guys for the reply , i got it done
Search this Thread |
