Old 12-08-2005, 12:41 PM   #1 (permalink)
slugger's Avatar
Default PARTITION MAGIC PROBLEM
I installed the demo version of Partition Magic 8 and tried to convert a FAT 32 drive into NTFS without losing the data, but was unable to do so. I got no error message for this.
Plz tell me what happened. Or is it not possible to do so with the demo version?
slugger is offline
Old 12-08-2005, 12:56 PM   #2 (permalink)
alib_i's Avatar
i dont know wht error occured ... but
if you want to convert FAT32 to NTFS then
go to command prompt :
type "convert C: /fs:ntfs"
replace C: by whatever drive you want to convert
alibi
-Metallica
alib_i is offline
Old 12-08-2005, 01:07 PM   #3 (permalink)
it is alway better to start a fresh partition instead of converting from fat to ntfs... by any 3rd party software...........
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
KnightRider is offline
Old 12-08-2005, 01:22 PM   #4 (permalink)
MVP in VC++
What error message u got?
cvvikram is offline
Old 12-08-2005, 02:01 PM   #5 (permalink)
Converted my drive to NTFS successfuly using partition magic. It might be due to demo version.
use method suggested by alib_i it is equally good.
Techmastro is offline
Old 26-08-2005, 08:15 PM   #6 (permalink)
slugger's Avatar
alibi
does this require partititon magic t6o b installed? Will my data also get erased after i do this? i don't wnat the latter to happen
slugger is offline
Old 26-08-2005, 08:21 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
No it doesnt require partion magic to be installed!
U'll not loose ne data.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 26-08-2005, 08:24 PM   #8 (permalink)
Don't worry you will not loose your data.. This method works...
shivaranjan.b is offline
- by Krow
