6800, tell me the compony & model, & cost
The 61.77 do not support the 6800 fully, U need to wait for the enxt driver release or use the non official drivers which were leaked from NVIDIA, I M using Forceware 65.73 on my FX5900XT, works really fine
U can download the
65.73 from guru3d.com, they are WHQL
Also download driver cleaner, then uninstall all the drivers U have in your PC, for gfx card then boot in safe mode, install driver cleaner & select to clean NVIDIA , this will remove all the leftover files from previous forceware installation, also remove all the ATI drivers from Driver cleaner & 3DFX drivers
After that boot normally & install the new drivers 65.73 from device manager,
any more help required?
